Question about Dell Inspiron 1501 Notebook
Inspiron 1501 won't turn on
My inspiron 1501 won't turn on, when power button is pressed the fans spin up and down , and the power light stays on intermittantly, is this a problem with the motherboard, thanks
  • aaronschmidt Oct 20, 2008
    i press the power button and the cd rom boots and the power light comes on but the screen is blank and the keys are locked. what is going on????
  • 3 Answers
It might be but there are a number of things we would check before calling the mobo bad. We use a process of elimination; stop when you find the problem and replace the bad bit. First, always try the easy stuff. reseat (remove and replace) the memory. If you have only one module try it in the other slot. If you have two memory modules try only one and try one at a time in each slot (four tries). Borrow compatible memory from a working laptop (ask your friends) and see if that does the trick. Put only one piece of memory back to continue (try to verify the memory in another machine). Last easy thing as a "might as well"; try on AC without the battery in and conversely on only battery. Next level: remove all the drives (and the battery too). Does it start now? Might as well remove the keyboard and try. Next level; leave everything out and reseat the CPU. I imagine that the model has a micro-PCGA socket and the CPU can be removed with the turn of a small screw. The CPU should be fairly accessible on that model from a bottom panel or under the keyboard. Remove any shielding and remove the fan and reseat the CPU. Replace the fan and try again.If still no luck then I would be pretty certain it is CPU or mobo. I might borrow a CPU from another machine but that is likely not an option for you. I might even buy a cheap compatible CPU on eBay but a better option for you would be to but a working parts machine of lower base on eBay. Don't buy only a mobo as you may have a bad CPU. Since you are committed to removing the LCD anyway you might as well remove the screen and see the bare base boots to an external monitor.
Good luck
alfadog
Posted on Oct 04, 2008
  • alfadog Oct 04, 2008
    "buy a working parts machine or lower base on eBay" - oops :)
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Power up laptop dell 1501 ,stays on until you logg on then after log on and programs load all power is lost
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 15, 2012 | Dell Inspiron 1501 Laptop
Dell Inspiron 1501 Power Button won't turn on ....
I would remove the hinge / power button cover again and make sure the little pip that presses the button down it not broken, also check the little circuit board with the switch on to make sure it's not disconnected.
Try switching on with the cover removed.
Feb 02, 2012 | Dell Inspiron 1501 Laptop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
It wont stay power up;and screen stays black; and shuts down after a second' please help'''''
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron 1501 Notebook
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1705 9300 17inch shuts down after 15-20 mins win xp
first thing to do is run psa test. turn off laptop. remove batt use ac adapter alone. press and hold on Fn key then press power button once. complete the quick test check if you will be getting error codes like 0142 , 0146 this is hard drive replacement.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
Won't post/boot
Try removing one of the two memory SODIMMS under the cover on the bottom of the unit. It sounds like you could have a bad memory problem that is keeping the machine from completing the POST (power on self test). I'd try one stick at a time and see if that helps.
Good luck, please rate this solution if you feel it has helped!!
May 13, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1501 Notebook Logo
3,296 people viewed this question
Alun Cox
