Question about Yahoo Messenger
Yahoo messanger installation
I have Vista, downloaded yahoo messanger vista version. whenever I'm trying to install a pop up msg is coming " yahoo messanger is unable to download files needed for installaiton. please check firewell settings and retry installation"
  • Anonymous Mar 25, 2009
    it shows same error,i did reset firewall but it shows same error:D
  • 3 Answers
Problem:
"Yahoo messenger is unable to download files needed for installation. Please check firewall settings and retry installation"
Solution:
I tried to solve this. I went through alot of forums. I uninstalled Yahoo messenger and tried installing new one. I downloaded and pressed "Run as an administrator" when i got this response
"Yahoo messenger is unable to download files needed for installation Please check firewall settings and retry installation."
I did the following:
Turned of Windows Firewall( Search )
Uninstalled Yahoo messenger
Downloaded New One
Used CCLEANER to clean the computer. Download CCLEANER from www.filehippo.com
Then I checked INTERNET EXPLORER:
Tools->Internet Options->Connections->LAN Settings -> Click on Automatically Detect Settings (Unclick everything else except this option) ->Apply -Ok
Check if www.yahoo.com opens in Internet Explorer.
Now Install Yahoo Messenger.
It should work.
Thanks
Posted on Nov 25, 2009
    Champion:
  • 200 Answers
Ok my friend i think now we can see there is a problem communicating between your computer (the installed program) and the yahoo server
so lets try these steps
first you can try this simple step and install yahoo again see if it going to work
go to start and in the search bar (lower left side of the list) type CMD (dont hit enter or anything just type it)
you will see on the left top side there is CMD and the icon is black
right click on it and select run as administrator and click continue when windows is asking to cancel or continue
now type in the black window
netsh firewall reset
hit enter
now close the window and try to install
if not working then you will have to disable the firewall, windows defender and all the security programs
that should solve the issue.
if you have any further question feel free to ask
dont forget to rate my answer :)
cheers
Posted on Oct 04, 2008
  • fynn_emerald Sep 10, 2011
    Oh man I cant believe it...finally advise that worked..Awesome..thanks :o)
  • Yahoo Master
  • 2,929 Answers
1) there is no need to adjust firewall settings to download Messenger
2) There is no longer a dedicated version for Vista
3)You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64
If that is not an issue read on.
The problem may be due to a mal-function of the uninstall software.
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
If u all have checked the proxy settings of ur browser(internet exploreras yahoo treats it as default 1 to pick up settings) then do check the proxy settings of ur connection. To do this go to internet options and under the connections tab u can c the dialup connections that areinstalled. Alogside u will c a settings tab. Click it and in dis uncheck all boxes and just give your dialup settings. the problem will surely be solved
Posted on Aug 11, 2010
Hi i have a questions and i hope u can help me when i am installing yahoo messanger it dose not installs and its a box comes out and its says side-by-side configuration what dose that mean and i really...
You didn't write that which operating system you using....but this error comes maximum in vista...it is related with Windows Resource Protection (WRP)...which use to keep your system file protected and secure....may be any of the file in SxS folder is corrupted or incorrect version.... You can try running sfc.exe(system file checker tool) to fix this....If you using vista, run your pc as an administrator and run cmd as an administrator as well. Type sfc /scannow and type Enter....while it running don't do other work on pc....it may take some time...be patient .....this command will scan all the protected system files, find out the incorrect version or corrupted version and replace with correct/suitable version....once you finish restart your pc and try install Yahoo messenger.
If you are a XP user, run your pc in Safe mode.and put the same command in cmd...and after finishing install yahoo messenger...
I think this suggestion will help you to fix your issue...
Thanks for joining Fixya...
Good Luck
Nov 12, 2009 | Yahoo Messenger
Everytime I try to install yahoo, i get a message from Program Compatibility Assistant that says: try using settings that are compatible with this version of windows. At the end, yahoo just says download...
Which operating system are you using? Windows xp or vista?? Try install that in safe mode or administrator mode....or try install latest version of Yahoo messenger 10 beta.... or download it from here http://download.yimg.com/ycs/msg/dl/msgr10/us/b4/msgr10us.exe
Further result please let us know....Thanks for using Fixya...Good Luck
Nov 08, 2009 | Yahoo Messenger
Cant use the yahoo messanger 9 with the new
Please try download and install latest version of yahoo messenger 10 beta ...it supports windows 7 also....download it from here
http://messenger.yahoo.com/download/winbeta/
or
Have a good time
Oct 27, 2009 | Yahoo Messenger
I can not install yahoo messanger 9.0.its take too many times
microsoft windows vista have a default messanger
remove the first time messanger and then install
Jul 10, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to download Yahoo messanger
Try downloading the full version of yahoo messenger straight away using the following link:
http://www.softwarepatch.com/software/yahoo-instant-messenger.html
Apr 10, 2009 | Microsoft Computers & Internet
When i installed yahoo messenger it did not open the window so i un-installed it and later installed it again but has encountered the same problem. The window is not opening.
Try rebooting your computer then do not open any programs except going to
http://messenger.yahoo.com/ and downloading new installer and save it to your desktop. Now double click it and run the installer.
If the above does not work or if you are using Windows Vista try using this link for the full installer (does not rely on yahoo servers). These full installers come directly from a yahoo server and by pass the web installer that most use. If on Windows Vista right click the full installer and choose install as administrator. You might have to temporarily disable the User Account Control (UAC). You can easily turn it back on. On the Control Panel (Category View) choose User Accounts and Family Safety, next choose User Accounts, and then click Turn User Account Control on or off.
Full Installer for Yahoo Messenger 8.1.0.421
http://us.dl1.yimg.com/download.yahoo.co...
Full Installer for Yahoo Messenger Beta 9.0.0.1389
http://download.yimg.com/ycs/msg/dl/msgr...
Full Installer for Yahoo Messenger for Windows Vista beta http://download.yimg.com/ycs/msg/dl/vmsg...
Feb 19, 2009 | HP Pavilion DV5234US Notebook Laptop
I downloaded Yahoo Instant Messanger 9.0 but it wont launch, keep getting message Yahoo Messanger has stopped working
First you have to uninstall the 9.0 version. Go to CONTROL PANEL----than go to PROGRAMS/FEATURES, or ADD/REMOVE PROGRAMS. Scroll down till you see YAHOO MESSENGER. Click on it and than click UNINSTALL
if you had trouble getting Yahoo! Messenger 9.0 to run on your Vista PC, please download and install the latest version (9.0.0.2034)
Dec 18, 2008 | Yahoo Messenger
Vista installed messenger logs in starts download of addresses and quits
you might want to download version 9 it's out now
might have fixed all those bugs that beta has
http://messenger.yahoo.com/download/win/
Oct 18, 2008 | Yahoo Messenger
My yahoo messenger has stopped working
hi , i also had the same problem, but i was able to fix it. dont know if its only for a while.
what i did was i uninstalled then installed Yahoo messenger . . then right click on the yahoo icon and select administrator . then the YM will pop out but still you cannot log in .
i then started to update my norton antivirus and then after it had installed the updates, restart your computer. after that dont know how it happened but it was fixed. i can log in
hope this helps
Oct 13, 2008 | Yahoo Messenger
Downloading Programs with the new Windows Vista
You need a special version for Vista if it's not what you tried to install already. It can be found here:
http://messenger.yahoo.com/windowsvista.php
Vista also pops up annoying prompts to confirm every system change, which may cause problems. This is caused by User Access Control, and I can walk you through temporarily disabling it if you can't get the above version installed straight away.
Feb 18, 2008 | Computers & Internet
Yahoo Messenger Logo
8,100 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
