I need power point to do my presentoin because i dont have it
    Genius:
  • 1,250 Answers
For this you have to install MS OFFICE PACKAGE
Posted on Oct 04, 2008
My washing machine stopped suddenly i dont know why !!
Hi Ebasel,
Test the power point with a lamp etc to ensure the point is active.
Boards are a common fault on washers.
Include your brand/model number & search online for availability.
Thanks
Damien
Nov 07, 2015 | Washing Machines
Bleed power steering on 2008 dodge avenger
to bleed power steering, with front wheels off ground slightly with front wheels pointing straight ahead.engine off. remove power steering filler cap.add power steering until fluid level stop dropping,wait couple minutes and wait, add fluid until level stay at full cold mark on power steering cap dip stick. dont over fill.when fluid level stop dropping, start vechicle,let it idle few minutes. see if fluid level drop if so add more fluid full cold mark.then turn steering all the way to left and right with out hitting a stop.turn steering wheel several times, then turn front wheels pointing forward check power steering fluid level.if power steering fluid level stop dropping air should be out of system, if steering turning wheel dont turn smoothly and power steering fluid look light tan color air getting in the system.check all power steering lines to rack and power steering pump for leaks.be sure you replaced all the power steering lines with new o rings if not you will get a leak.if you find a leak, you need to fix the leak and bleed system again.dont drive vechicle if your steering dont feel right,have vechicle towed to a garage.
Aug 25, 2012 | 2008 Dodge Avenger
Nothing on my lofra oven works small oven fine top fine oven died no lights or fan
Hi You need to check out the fuses and the power supply. Dont forget to check the power point as well.There seems to be no power supply to the unit.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi ive just got a cb900f2 boldor. It has been in a shed for 5 years, previous history unknown. The seller has put new plugs and carbs on it. It will whind over but no spark at plugs. I dont know alot...
pick ups work similar to points
The coil needs power, when the points open the coil field collapses and it sparks
With pickups they trigger the electric igniton box to do the same job as points.
if you have power to the coils, when you touch a pick up with a screw driver it should trigger a spark.
You dont often get two coils fail or two pick ups fail simutanously, but a faulty ignitor box will stop all spark.
PS (not ignition related)Check the rivets in the wheels if it has them
May 09, 2011 | Honda CB 750F2 Seven Fifty Motorcycles
But i dont have powerpoint.i have powerpoint viewer
Power Point Viewer will allow you to view Power Point Documents, but it will not allow you to create a Power Point presentation. If you want to create a Power Point presentation you will either need to purchase Microsoft Officer, or take a look at free alternatives like OpenOffice: http://www.openoffice.org
Feb 17, 2011 | Microsoft PowerPoint for PC
How do you get micro soft power point
You dont need ms power point, you can download a free copy that is like power point called open office here: http://download.openoffice.org/contribute.html?download=mirrorbrain&files/stable/3.2.1/OOo_3.2.1_Win_x86_install-wJRE_en-US.exe
please leave me good ratings, thanks.
Sep 04, 2010 | Computers & Internet
Dont have power problem need start up disk
Your HDD Partition selection in bios has changed. The default HDD partition pointed in BIOS points a non System Disk. Just go to BIOS, change the HDD partition selection for booting and your problem would be solved. If not solve, none of your partition is made system. Then just use a installer CD or repair CD and fix in command mode. Too much tutorials on this subject is over net and I am not writing those here for that reason.
Jan 29, 2010 | Apple Titanium G4 and 8413i Book series AC...
12v charger dont work, what fuse is it
The cigar lighter is fuse # 41.
The 12 V power plug ( Ford calls it a power point ) on the dash is fuse # 39
The rear power point is Fuse # 37.
Oct 08, 2009 | 2006 Ford F-150
My computer will not let me create a power point slide show
Just cause you have a new compuer it does not mean you have all of office suite. Look for word, excel and power point on your accessories button. You have to activate them and buy them for about $100 or so to buy them from Microsoft.
Rate this solution before logging off.
Mar 15, 2009 | Microsoft Windows Vista Home Basic for PC
Power conversion
Dont do any thing with your printer power supply and just purchase Step-Down AC Transformer. Its input will be 220Volts AC and will out 110Volts AC. One thing important, read the printer power consumption watts and get proper one. Got the point buddy?
May 29, 2008 | HP LaserJet 1200 Printer
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
