Question about Philips DVP-3005 DVD Player
Small glitches with home-burnt DVDs only
Commercial DVDs work fine. Commercial CDs and home-burnt CD-Rs also work fine. Only with home-burnt DVDs (both -R and +R type) does a brief regular glitch or hesitation in both video and audio occur, at the same point in the disc each time, and repeating every couple of minutes. This happens irrespective of the disc burning source (both computer and DVD Recorder), and the fault does not appear on other DVD players used for comparison. I suspected a sticking carriage in the mech., but perfect repro of all the other above-mentioned discs seems to disprove this. The glitch lasts less than half-second each time.
Thanks, Colin Doman
  • Anonymous Feb 10, 2009
    I'm suspecting there's a memory problem on this player...
    My landlord burnt his holiday snaps onto a dvd, and the player locks up when it tries to display them. Sometimes it displays one or two, and then locks up, sometimes just one. My suspicion is that the files are too big for the player to store in the buffer. It can handle one, but it may try to load them into memory before viewing or something...
Gents,
Not a solution but in case it may help other's understanding with a similar problem, found glitch to be related to the default Chapter-making process within the Panasonic DVD recorder when dubbing a DVD. Default appears to be 5 mins 20 seconds per chapter, i.e. 320 seconds. Glitches from these DVDs are seen regularly on two of my four DVD players at every 32 seconds, i.e. one-tenth of the chapter length. Can't explain why this happens, or why indeed two of the players sail-through this recurring glitch without problem.
Colin Doman
Posted on Nov 13, 2008
Desktop DVD fails to recognize "commercial" DVDs
Hello my friend,i can think only 2 things.The first thing is the region code.So right-click My Computer then select Properties,select the Hardware tab,click the Device Manager button and go to DVD/CD-ROM drives,double click to open the tree.Then choose your dvd burner and double click or right click and properties to open the dvd properties.Go to the dvd region code and select the code/country that the dvd supports and click OK.Also you can download a program called region free.The second thing is that your drive supports CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD+R DL, DVD-R DL, DVD-RAM so if the disc is something else then is not supported by your reader/burner.
Feb 08, 2010 | LG GSA-H55N DVD-RAM Burner
Car cd player won't read cds
I have a Dual xdvd8180 dvds multimedia reciever 7" digital touchscreen in my car and it worked fine for the longest time but now it wont read any of my cds.. burnt or original discs.. nor will it read dvds.. i tried cleaning it with a disk cleaning kit and it wouldn't even play that without skipping..idk whats wrong.. any help??
Jan 04, 2010 | JVC AM FM CD DET FACE CAR STEREO
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
My DVD player has had continual playback problems for many months. It skips and pauses often while playing back DVDs and CDs. These same CDs and DVDs play flawlessly in other (much less expensive) players...
Might need a tune from bose repair man, Burnt dvds sometimes has problem but wipe normally fixes it. But cds i have't had problem burnt or orginal, scraches dont usally worry to much, Thats why thinking repair man.
Hope this helps:)
Cd normally hot from unit if its in for a while.
Aug 16, 2009 | Bose Lifestyle 38 System
My DVD drive in ACER Aspire 4720 not reading burnt DVDs and CDs
well look for cds that are thicker and sturdier. some low cost CDRs are too thin and/or soft that they cant handle the heat generated by the cd drive.
Jun 04, 2009 | Acer Aspire 4720 Notebook
Cd-drive won't read burned audio
try installing some decoder s/w available over internet
Feb 03, 2009 | Sony Computers & Internet
Some cd work with my laptop but some donot open. why? pls help
check your cd drive and see if it accepts cd-r and cd+r, if not then it is possible that only one or the other will work on your drive.
Nov 30, 2008 | Computers & Internet
Will not play CD-Rs
DVD players will play CD's and MUSIC CD-R's. Some will play MP3's IF the unit is so designed. You would see the 'MP3' logo on the front.
Aug 20, 2006 | Samsung DVD-V1000 DVD Player/VCR
Philips DVP-3005 DVD Player Logo
166 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
