Question about EliteGroup GeForce 6100SM-M Motherboard
SPDIF out, wrong pin configuration?
Hi... Could someone please help me with this? In my mb manual, spdif out connector pin config is supposed to be:
1-signal
2-5v+
3-no pin
4-grnd
problem is, on the board, pin 1 is on the left (it has a '1' next to it) and there's no pin 2 but 3 and 4 are there.
I need to output sound through the hdmi port on my 9600gt vid card and it has an spdif in connector for that purpose with red wire for signal and black for grnd. Which are the right pins on the board?
Yours eternally grateful,
Maria.
xxx
  • Rick May 11, 2010
    if pin 3 is not used and they marked pin 1 on the left. possible they mark the wrong end on the motherboard. have you tried to donnect the other way ?
Where can i find the spdif and ground on my mcp61pm-am mb
This motherboard doesn't have an spdif connector. The ground can be any metallic part of the case.
May 27, 2010 | Computers & Internet
945GCT - HM motherboard, SPDIF out?
Hi, Before doing anything please refer the motherboard manual, and as per my knowledge you need not solder any pin on the board, if you do so may be something else might not work. I better suggest you to check the Manual before doing anything.
Regards
Feb 22, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
MCP61PM-HM spdif pin assignment? trying to
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
Nov 28, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Aug 11, 2009 | ASUS Intel 5000P Chipset...
ECS MCP61PM-HM SPDIF Header
diagram at HP support forum sows board and labels for connectors.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=87&query.id=879674
Oct 28, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Spdif pins
First of all when you got these pictures were they from *********** board?If they were did you wear a wrist bracelet to prevent Electro Static Discharge (ESD)? If not you may have just ruined your computer. But there is a chance you didn't. Next I am not positive but you might need to get a three pin SPDIF connector from Radio Shack. But I would try the one you have. See if it works. But I must warn you going inside your computer if you are not a technician can be very harmful to your computer. So if you take my advice Touch some part of metal on the outside edge so you are grounded to your computer.
P.S. Damage from ESD may not be right away. It can be months from when the computer was shocked. If my advice doesn't work tell me and i will give you much more help.
Hope this Helps.
RCF
Apr 26, 2008 | Creative Labs Sound Blaster Live! 5.1...
EliteGroup GeForce 6100SM-M Motherboard Logo
594 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
