Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Wrong ip address, need to reconfigure
I have a working router and adapter. The adapter's port went bad, so it got unplugged. I plugged it in another port and now I have limited or no connectivivty. Linksys won't tell me how to reconfigure w/o paying them again. Please help if you can.
Sincerely, Diane
    Novelist:
  • 173 Answers
Hi Diane,
If your getting limited or no connectivity on your wireless connection on the computer more or less you have enabled wireless security on your router and you need to delete or configure the wireless settings on your computer and make sure that you entered the correct security settings. For example if you had enabled WEP 64bit on the router, you should go to the wireless connection properties of your wireless adapter and go to wireless networks, there you can select your network name and click on edit or configure, enter the correct network key(normally if its WEP it's either 10 or 26 digit if it's WEP 128bit).
Posted on Oct 04, 2008
Connect network wireless
If you are using this as ethernet adapter, there definitely are IP addresses for each cable plugged into the router. Your MAC needs an IP address for the router to ROUTE the traffic to and from the internet. That's what Routers DO. Listen to your Support. Unplug all other devices from the router you connect to, then connect your adapter, and let the router assign an IP address to it. Then connect the rest of the devices one at a time, and see if that works. Make sure you plug the cable from the efibre to port #1 on the router, for highest priority of traffic.
Sep 13, 2013 | EMC LightPulse LP11000-E Fibre Channel...
Wireless router was working now its not, now light showing wireless on the router, I have internet if i plug in derectly to the modem
Jus Powercycle the Whole N/w
Unplug Modem and Router
Plug Modem First and then Router
Check Wired Internet to Router if that Works, wireless will be Online
Oct 01, 2010 | Linksys Wireless-N WRT150N Router
Aaarrrrh its doin me head in
A. Determine the IP Address and MAC Address of the Xbox.
Note: You may find the IP address and MAC address of your Xbox on your Dashboard's Network Settings. Please refer to your Xbox manual for more information on this.
B. Reserve the IP address.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. For security reasons, the router has its own user name and password. When prompted, enter admin for the User name and password for the Password, both in lower case letters.
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address, and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Forward the ports.
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type.
2. Click Add and another window will pop up.
3. Type Xbox for Name. Set the radio button to Enable.
4. On Outgoing Port Range, set the Start Port and End Port to 3074.
5. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply.
6. Please repeat steps b to e and indicate 88 for Start Port and End Port. Then change the Name to Xbox2.
Note: If it still does not work, you may try these other options:
D. Lower down the MTU.
1. Access the Setup page of the router (refer to Step 2 above).
2. Click on the WAN Setup under Advanced tab.
3. Lower down the MTU size to 1492, 1400, 1358 or 1300.
4. Click on the Apply button.
E. Enable UPnP.
1. Go to UPnP tab of the router.
2. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router.
F. Upgrade the firmware.
Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router.
1. Please verify the router version and model either underneath or at its side panel.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
3. Click the appropriate version of the router.
4. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with Wired or Ethernet connection only.
5. Before upgrading, please write down all current settings since you need to enter them manually.
6. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2).
7. Click on Maintenance and then Router Upgrade.
8. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
9. Please wait for the router to reboot. After a successful firmware upgrade, you need to reset the router.
E. Reset the router.
1. Please push the reset button at the back of the router and release after 30 seconds.
2. Unplug the power adapter for 10 seconds and then plug it back in.
(this note should go before the step to Reset the router) Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Jul 08, 2009 | NetGear WGR614 Router
I have a netgear ant. and a linksys ant. will either one work on my xbox 36o so I can play games online
A. Determine the IP Address and MAC Address of the Xbox. Note: You may find the IP address and MAC address of your Xbox on your Dashboard's Network Settings. Please refer to your Xbox manual for more information on this. B. Reserve the IP address. 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. For security reasons, the router has its own user name and password. When prompted, enter admin for the User name and password for the Password, both in lower case letters. Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address, and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Forward the ports. 1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type. 2. Click Add and another window will pop up. 3. Type Xbox for Name. Set the radio button to Enable. 4. On Outgoing Port Range, set the Start Port and End Port to 3074. 5. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply. 6. Please repeat steps b to e and indicate 88 for Start Port and End Port. Then change the Name to Xbox2. Note: If it still does not work, you may try these other options: D. Lower down the MTU. 1. Access the Setup page of the router (refer to Step 2 above). 2. Click on the WAN Setup under Advanced tab. 3. Lower down the MTU size to 1492, 1400, 1358 or 1300. 4. Click on the Apply button. E. Enable UPnP. 1. Go to UPnP tab of the router. 2. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router. F. Upgrade the firmware. Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router. 1. Please verify the router version and model either underneath or at its side panel. 2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router. 3. Click the appropriate version of the router. 4. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop. Note: Please perform firmware upgrade with Wired or Ethernet connection only. 5. Before upgrading, please write down all current settings since you need to enter them manually. 6. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2). 7. Click on Maintenance and then Router Upgrade. 8. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload. 9. Please wait for the router to reboot. After a successful firmware upgrade, you need to reset the router. E. Reset the router. 1. Please push the reset button at the back of the router and release after 30 seconds. 2. Unplug the power adapter for 10 seconds and then plug it back in. (this note should go before the step to Reset the router) Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Jun 12, 2009 | NetGear WGR614 Router
Router not connecting properly
The NETGEAR router is a firewall. It blocks ports to prevent attacks from programs or users from the Internet to the computers or devices behind your router. Each application on the Internet uses ports. For example, when you browse the Internet, it uses port 80. An FTP server uses port 21. This is the same as your Xbox that uses ports to connect to the Internet. Before we proceed to any troubleshooting procedures, check if the Xbox is working directly to the modem. This will verify if there is something wrong with the Xbox. If the game console won't connect to the Internet when directly connected on the modem, it means that it is not your router blocking the connection. Here are the steps on how to open the ports on the router:
E. Enable UPnP.
May 23, 2009 | NetGear WGR614 Wireless Router
I need to switch me nat from moderate to open on my router
E. Enable UPnP.
Apr 02, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Xbox 360
E. Enable UPnP.
Mar 24, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Im assuming youre using an integrated ethernet card since you say "adapter port" and "unplugged". So....
Since you reformatted your HD with O/S re-installation you may also have to reinstall or update it to the correct ethernet adapter driver. As far as the ethernet card set-up - copy your ethernet card property configurations from the other computers. Also copy configuration settings from your Internet Explorer options.
Jan 11, 2009 | Linksys Wireless-G WRT54GS Router...
Trying to connect xbox to to netgear wireless router. Router will not issue an IP address.
Dec 27, 2008 | NetGear WGR614 Wireless Router
I cannot connect to the internet through my netgear router.
Dec 19, 2008 | NetGear WGR614 Wireless Router
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
157 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
