Question about Dishwashers
Indesit de3542 starts to go but stops after about 30 seconds
  • petermallows Oct 04, 2008
    how do i get to this component to replace it
    Master:
  • 479 Answers
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit ( there are others, this is just an example )
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
step by step instructions and diagrams for How to remove the access panels
just click this link
http://www.applianceaid.com/dishaccess.html
My dishwasher will not start:
Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
My dishwasher will not fill with water:
This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Posted on Oct 04, 2008
    Sergeant:
    Champion:
  • 200 Answers
Hi
You can find the spare parts from this link
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
  • Thafa Oct 04, 2008
    HI
    check out this link how to check the timer
    http://www.acmehowto.com/howto/appliance...
    President:
  • 1,952 Answers
Check power is loose connect then
Water supply to the dishwasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!!
  • 19,396 Answers
Start by unplugging the appliance for ten minutes, and eventually advance the cycle so to drain water inside and complet the cycle.
If you still get the problem, then the timer control is probably faulty, and need replacement.
Insert model number here to get parts and diagrams telling you hoe to replace it.
If you want to call a repairman use the phone number listed on the owner manual.
    Genius:
  • 1,269 Answers
That is a discharging problem. What you can try initially is turn it off and unplug the power cable for about 2-3 hours to release any static charges. Then plug it back in. If that doesn't work, there's an internal electronics component that needs to be check. Discharging is a capacitor problem. There might a burned or bulged capacitor that needs to be replaced.
  • Michael Galve
    Michael Galve Oct 04, 2008
    The unit's casing needs to be taken apart to visually see the defective component. If you cant do it, its better to have it serviced by a technician or bring it to the nearest electronic repair center.
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit WIL 153
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe would be good too.
Feb 02, 2008 | Indesit WA 115 Front Load Washer
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
