Trying to hook my camcorder to my computer in order to transfer video and eventually burn a DVD.
I used the USB cable from camcorder USB out to computer USB in. The computer is not recognizing the connection.
So what is left?
I see this iLink thingy, but I don't have iLink input on my computer.
I don't see any other cables that Sony has included that will help.
How do I get started?
Also, do I need to go into my camcorder menu and select anything in order to transfer HD content to my computer and have it downconvert to SD for burning?
-   I have a sony DCR-HC47E and im having problems with connecting it to the computer by USB cable that came with it.Im getting this i-link blocking that is just not going.I want to transfer video on tape to the computer.
Thank you in advance.-   Guest
Jan 10, 2008
-   How do you get HDV video loaded into a computer for editing in HDV?
Have found that HDV - DV video conversion in the Sony HDC-HC1 Camcorder creates fuzzy images - that have lower quality than those loaded from a standard Sony DV camcorder.
You will need a firewire port (aka iLink) on your computer to capture video from HC1. USB can be used only to transfer still photos. Firewire cards are cheap and easy to install. In order to make your camcorder downconvert HDV to DV go to "STANDARD SET" menu, select "VCR HDV/DV" option, and set it to "DV". Once you do it, the computer will recognize HC1 as a DV device (provided it is hooked up through firewire) and you will be able to capture the video using any software that works with DV.
Was this helpful?
Yes
No
Popular Solutions for Sony HDR-HC1 Mini DV Digital
The touch panel does not work in flip out mode(standard mode). However, it works when you flip the...
(More)
The touch panel does not work in flip out mode(standard mode). However, it works when you flip the panel to view on the side of the camera. The battery test worked and I can view from inside.
cam stop working doesn't power up and screen will flash white about every 10 sec ? can you help...
(More)
cam stop working doesn't power up and screen will flash white about every 10 sec ? can you help thanks
the lcd panel on my hdr hc1 is not working properly. I am unable to access the menu and the frames...
(More)
the lcd panel on my hdr hc1 is not working properly. I am unable to access the menu and the frames keep moving on the screen.
