Question about Microsoft Office Professional 2007 Full Version for PC
Program for file protection (folder protection)using c
I want c program for folder protection in windows
    Genius:
  • Microsoft Master
  • 1,250 Answers
You can load software like folder guard
Posted on Oct 04, 2008
How do i view the backup from my previous computer ? i can see the photos from my iphone and one pdf file, the files from the computer are "protected"
Eortiz, did you try to read the files with a windows PC? Because when you connect the external drive to a PC you should be able to view the files and even be able to change the attributes like read only and hidden.
May 12, 2014 | Hitachi Touro Mobile Portable External 1...
Tip
How to Make Invisible Password Protected Folder Submitted by Srikanth on...
How to Make Invisible Password Protected Folder2761870.jpg Submitted by Srikanth on Thursday, 10 December 200930 Comments Do you want to password protect your folder? Do you want to make it invisible so that it remains unnoticed by the normal users? Well here is a way to do that. In this post I will show you how to make a password protected folder in Windows without using any additional software. Here is is step by step procedure to create a password protected folder.
How to create a Password Protected Folder
Step-1: Create a new folder (Right-click -> New -> Folder) and give it any name of your choice. For instance I name it as ABC.
Step-2: Now in this folder place all the important files, documents or any folders that you want to password protect.
Step-3: Now Right-click on this folder (ABC) and select the option Send To -> Compressed (zipped) Folder.
Step-4: Now a new compressed zipped folder gets created next this folder (ABC) with the same name.
Step-5: Double-click on this compressed zipped folder and you should see your original folder (ABC) here.
Step-6: Now goto the File menu and select the option Add a password.
ie: File -> Add a password
Now a small window will pop up and here you can set your desired password. Once the password is set, the folder will ask for the password every time it is opened. Thus you have now created the password protected folder.
How to make it Invisible
Step-1: Now Right-click on this password protected folder and select Properties.
Step-2: At the bottom select the option Hidden and press OK. Now your folder gets invisible (hidden).
Step-3: In order to unhide this folder go to My Computer – >Tools -> Folder options. Switch to View tab, scroll down and under Hidden files and folders you’ll see the following two options
  • Do not show hidden files and folders
  • Show hidden files and folders
Now select the second option and press OK. Now the invisible folder becomes visible in it’s location. To access it you need the password. To make it invisible again repeat step -1 through step-3 and select the first option and click OK. Now the folder becomes invisible once again.
I hope you like this post. Pass your comments!! Cheers
on Mar 30, 2010 | Computers & Internet
Tip
How to delete files that are used by other programs in windows XP/Vista?
Today tip will help you to delete the files and folders that are being used by another programs and applications, for example a virus affected file. You have tried to delete such kind of files or folders and received the any following messages.
· Cannot delete file: the file is in use by the other program
· Cannot delete file: There has been a sharing violation
· Cannot delete file: The file is in use by another program or user
· Cannot delete file: Disk is not full or write-protected and that the file is not currently in use.
· Cannot delete file: The source or destination file may be in use
Normally, a windows restart will allow you to delete such files or folders that are being used by other program, but if you want to manage it without restart your computer then simply you need to download a freeware tool called Unlocker.
You can download this tool for any windows version using Unlocker link. Download it and run the easy setup.
After installation, right click on file or folder that you want to delete and select the option Unlocker.
If your requested file or folder is used or locked by other application then a small window listing of lockers will appear.
Here simply click on “Unlock All” button and now you can easily delete this file.
Thanks,
Bhautesh.
on Feb 23, 2010 | Computers & Internet
Hi im anthony and i had bought a laptop from a guy and it has k9 web protection on it and im tryn to get it took off can u pleasde help me
there are two methods you can try.
Method 1
If you have the administrator account password for the local computer and the best way to uninstall K9 web filter from the local computer is to re-install it! Re-install k9 web protection will simply get you a new license code and a new password you can enter without the need of old password.
1.Open K9 web protection website 2.Click "get K9 NOW" tab on the top-left 3.Fill out the information and your email. 4.Download the K9 Web protection software from the link included in the email and keep a copy of the license. 5.Grab a version of the K9 web protection installed on your computer, a Google search should do the job. 6.Open "Task Manager" by press (Ctrl+Alt+Delete) and end the process K9filter found in the "Process" tab. 7.Now, you can safely delete the K9 web protection program files. Open computer explorer and go to the folder where K9 is originally installed. It can be found mostly at C:\Program Files/Blue Coat k9 Web Protection. 8.Remove the contents of the folder but not the folder. 9.Run the K9 web protection setup/installer file which has the same version as the one you just delete 10.Provide the license and create your new password 11.Point the installation folder to the same folder you just empty the contents earlier on 12.Now you can have a re-installed K9 web protection with a password you know. How do you uninstall K9 web protection now? Use the new password you just created If something goes wrong, install the K9 web protection program downloaded from Step 4.
Method 2
Reboot Windows into safe mode: restart your computer and hold "F8? key until you see the menu to choose "Safe Mode" Login to windows and go to "Program Files" directory and delete the K9 folder manually (delete only the contents but leave the folder) Click "Start"->"Run" and type "msconfig" Check the tab "Services" and tab "Startup" Un-check anything that is related to k9 If somehow this method is messed up, try to download K9 again to at least restore your previous installation. If this still does not work, try to install Revo Uninstaller.
Here is a video tutorial
Aug 24, 2011 | Dell Inspiron 1501 Notebook
Password Protect...I use Vista Home. When I go to save a file. FILE-Save AS the window that comes up has an option of "Save with Password". This option is ghosted out and can not be selected.....
There are a couple of ways to do this.
Try going to Tools;
Then Options;
Click on security Tabs;
you will see this
Got to Password to Open;
Click Ok;
Fill it in and you will see this;
Re-enter your password;
Click Ok.
Save the file like you normally would.
This should resolve your issue.
Make sure you check your registry for Windows Vista for errors to see if that is causing the problem also.
I am including another link you may be interested in for your IE passwords also.
http://www.watchingthenet.com/enable-internet-explorer-prompting-to-save-passwords.html
Let me know if you need anything further!
Thanks for using Fixya!
KittyTech
Mar 11, 2011 | Computers & Internet
Password Protecting a File...I have in the past done done this but forgot how...I remember I went to File-Properties-Security-Protect and then entered the pw I wanted to use....That doesn't work so...
Welcome to Fixya. If you want to protect or a File or a Folder you can follow the steps below.
Windows XP Professional
1. Select the folder you wish to encrypt.
2. Right-click the folder and click Properties.
3. Click the Advanced button.
4. Check "Encrypt contents to secure data" option.
5. Click Apply and then Ok.
Windows XP Home
3. Click the Sharing tab.
4. Check the box Make this folder private
The ability to encrypt files and folders is not available in Windows Vista Starter, Windows Vista Home Basic, and Windows Vista Home Premium
If you want to protect a Word Document please click on the link below.
How to password protect a Word document
How to password protect a Word document 2010
If you have questions please let me know. Thanks for using Fixya.
Mar 07, 2011 | Computers & Internet
RAN RECOVERY DISK AND NOW CAN'T GET ON LINE
The suspicion of possible errors in the system files in Windows, it may be worth a try to run the "hidden" program that comes with just Windows.
System allows an administrator to scan all protected files to verify their versions.
If System File Checker discovers that a protected file is overwritten, it retrieves the correct version from the cache folder (% Systemroot% \ System32 \ Dllcache) or source files for Windows installation, and replaces the incorrect file.
System File Checker also checks and filling up the cache folder. You must be logged on as an administrator or a member of the Administrators group to run System File Checker.
If the cache folder becomes damaged or unusable, you can use the sfc / scannow, sfc / Scanonce or sfc / scan boot to repair its contents.
To use SFC:
1) Press Start
2) Select Run ...
3) Enter: sfc / scannow and press OK
you should find the windows cd and put itin the cd player on the PC, if you have some corrupted system files so the process will bring it from cd to the computer
Sep 09, 2010 | HP Computers & Internet
Will not allow me to install Reader 9.2 Error
try to completely UNINSTALL your adobe reader program. Then reinstall it. If the problem persists, uninstall the program again (Adobe reader) and delete the Adobe Reader folder in your Program Files folder. Then reinstall.
Nov 05, 2009 | Adobe Acrobat 7.0 for PC
I have same problem
The D drive is normally a partition of the C drive rather than a separate drive and is used by many to keep restore files handy for restoration use; system backdating to refresh system files. The D partition, while available and accessible for other purposes is customarily not used for user files and because of the nature of the system installed files, has protection against accidental erasure.
You should be able to copy your photo folders & files intact back to the C (main) partition and regain normal use of them.
Jul 25, 2009 | E-Machines W3107 (RBW3107) PC Desktop
Password on shared documents on a workgroup
Password Protect Folders in XP
To password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
If you have a log in password for your account, this can be used to protect folders from other users. If not, you need to creat one. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
Right-click the folder that you want to make private and choose "Properties" (or Alt+Double-click). Go to the "Sharing" tab and check the "Make this folder private" box.
Click Apply . If you do not have a password on your account, a box will pop up asking if you want to assign a password. This must be done if you want to make the folder private, so click Yes . You will need to use your password to log on to your computer from then on.
Type in a password then confirm it. Click the "Create Password" button then close the Password window.
Click OK in the Properties dialog box.
Now anyone else logged on to your computer can't access that file without knowing your password.
Dec 02, 2008 | Microsoft Windows XP Professional
Microsoft Office Professional 2007 Full Version for PC Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
