Is it possible to record movie with sony HDR-HC1 and save the movie on the pocket hard drive through firewire port? If yes, what type or brand name is recommended? and does the drive needs a power supply?
I *really* doubt something like that is available.
You can save your PHOTOS onto a hard disk (e.g., use an iPod with the Belkin media reader) but I would be pleasantly surprised to find anything for movies.
The touch panel does not work in flip out mode(standard mode). However, it works when you flip the...
(More)
The touch panel does not work in flip out mode(standard mode). However, it works when you flip the panel to view on the side of the camera. The battery test worked and I can view from inside.
cam stop working doesn't power up and screen will flash white about every 10 sec ? can you help...
(More)
cam stop working doesn't power up and screen will flash white about every 10 sec ? can you help thanks
the lcd panel on my hdr hc1 is not working properly. I am unable to access the menu and the frames...
(More)
the lcd panel on my hdr hc1 is not working properly. I am unable to access the menu and the frames keep moving on the screen.
