Repair start up failure - Computers & Internet
    Novelist:
  • 171 Answers
Well it depends on how severe is your start up problem, if the OS still loads lets say on Windows XP more or less you just have to repair the boot.ini, if you have your Windows XP CD load it to your computer(make sure that on the BIOS setup the intial boot devce must be your CD ROM) When the initialization finished press R to open the command prompt the type the following;
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Posted on Oct 04, 2008
The audi is now starting but not moving its triptronic i let it been restart but nw it show all gears and not moving
tow audi to transmission repair shop
the transmission low on oil
the transmission computer module not gone in to fail safe
solenoid failures
gearbox internal failure
torque converter failure
Oct 31, 2016 | Audi Cars & Trucks
Please help! It turns on, command light is flashing green, no turn off, doesnt move if i dont put water in manually
Failures, which occurred during the program will store and indicate for customer by flashing start LED (light-emitting diode). Appliances which have no program sequence or no 7-segment display can't exatcly show the failure. On these appliances the failure can only be found by starting the test program.
The passive test program shows the stored failure. If there is no failure the passive test program runs normal.
1. Switch off the appliance
2. Push start button and hold it
3. Choose position 1 of the "turning knob" turning right side (program 1).
4. Finish pushing the start button when the start LED flashes.
5. Failure indication
6. Repair the failure
7. Solve the failure by pushing the start button for longer than 3 sec.
8. Start the passive test program again. If there is no failure detected, test all LED's and after that choose program 1.
9. Finish the passive test program by pushing the start button for shorter than 3 sec.
Thank's to your description of failure I will check all hydroulic inlet water circuit and electrical component in "inlet water" phase (electrical valve, flow meter (if exist), OWI, VWI, wiring, CB...etc)
Dado
May 30, 2015 | Whirlpool Dishwashers
My computer says it can not repair automaticlly then when i click finish it shuts off
In Startup Repair please select "System Restore" and restore the system back to a couple of days before the problems started. That will fix the issues with corruption of the registry.
If that does not help, try to see if you can start in safe mode - Pressing F8 at startup will give you safe mode options.
If neither works, it's possible that it is a hardware failure of some type. most likely a MoBo failure.
If you are able to start it up in safe mode, I would grab a USB thumb drive and save what files you can.
Mar 01, 2013 | Computers & Internet
1996 Jimmy only 2nd gear any suggestions?
YOUR TRUCK TRANSMISSION IS IN A "DEFAULT MODE" GIVING YOU SECOND GEAR ONLY TO PROTECT FROM DAMAGE DUE TO AN ELECTRICAL OR MECHANICAL FAILURE AFFECTING YOUR TRANSMISSION, YOUR WILL NEED TO PLUG IN A ENGINE CODE SCANNER TO RETRIEVE SOME COMPUTER FAILURE CODES, CODE YOUR WILL BE LOOKING FOR START WITH A P0700 ON UP, BUT DO NOT IGNORE ANY ENGINE FAILURE CODES, GENERAL REPAIRS PROCEDURES REQUIRE THAT THOSE BE REPAIRED FIRST.!. SCAN YOUR VEHICLE AND RE-POST THEM BACK, I WILL HELP YOU FURTHER.
Jul 01, 2011 | 1996 GMC Jimmy
My XPS M2010 had a pop up when I went to turn it on today. I beleive that it never shut down. Pop up said program did not shut down properly do you want to find solution and close or close program. I chose...
There are two reason for this error message
1 Hardware failure
2 Software failure(OS)
To eliminate hardware failure run the hardware diagnostics on the computer.. Use the link
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If all the hardware is working well then the issue is with the OS - reinstall it
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Dec 07, 2010 | Dell Computers & Internet
Hp ml350g4 p server hang on diagonestic screen, unable to set standard boot order(ilo)
To repair your installation of Windows, follow these steps:
1. Insert the Windows Server 2003 CD in the CD-ROM or DVD-ROM drive.
2. If the Windows CD displays the What would you like to do? menu, click Exit.
3. Turn off your computer, wait ten seconds, and then turn your computer back on.
4. If you are prompted to start your computer from the CD, do so.
Note You must be able to start your computer from the Windows Server 2003 CD-ROM to run Windows Setup. Your CD-ROM or DVD-ROM drive must be configured to do so. For information about how to configure your computer to start from the CD-ROM or DVD-ROM drive, see the documentation that is included with your computer, or contact your computer manufacturer.
5. After Setup starts, press ENTER to continue the setup process.
6. Press ENTER to select the option To set up Windows now, press ENTER. Do not select the Recovery Console option.
7. Press F8 to accept the licensing agreement.
Setup searches for previous installations of Windows.
* If Setup does not find a previous installation of Windows Server 2003, you might have a hardware failure.
Hardware failures are beyond the scope of this article. See a computer hardware specialist for more help or try the Hardware troubleshooter. For more information about the Hardware Troubleshooter, see the Windows Server 2003 Help topic "Using Troubleshooters."
* If Setup does find a previous installation of Windows Server 2003, you may receive the following message:
If one of the following Windows Server 2003 installations is damaged, setup can try to repair it. Use the up and down arrows to select an installation. To repair the selected installation, press R. To continue without repairing, press ESC.
Select the appropriate Windows Server 2003 operating system installation, and then press R to try to repair it.
* Follow the on-screen instructions to repair the installation.
Notes
o You might have to change the boot drive sequence in your BIOS settings to successfully start your computer from the Windows Server 2003 CD. Contact the manufacturer of your computer, or see your manufacturer's documentation, for more information.
o If you cannot start your computer from the Windows Server 2003 CD, you might have a CD-ROM or DVD-ROM drive failure or other hardware failure.
o After you repair your Windows Server 2003, you may be required to reactivate your copy of Windows Server 2003.
Jan 22, 2010 | HP Compaq ProLiant ML110 G4 Server
What are errors 1to5 and 7to8
1- face down sd ram failure
2 face up dram failure
3 cpu dram failure
Sep 23, 2009 | Kodak i30 Path-Through Scanner
Computers & Internet Logo
180 people viewed this question
David Payne
David Payne
