Recover data on WD1600
Someone plugged a 17v power supply (instead of 12v) into a WD 1600 Serial ATA drive. I extracted it from the USB housing and tried it with a separate 12v PS and SATA/USB 2.0 adaptor, but it still doesn't work. Do you think you could do more disassembly and recover the data from the disk?
    Sergeant:
    Champion:
  • 334 Answers
Ya pull hard drive plug it in diecrt into comp off stat port as slave drive go in safe mode drag drop info on to new hd if u can k
Posted on Oct 07, 2008
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
Oct 11, 2012 | Macally G-S350SUA 3.5" Hard Drive...
I plugged in a 19v adapter to my 12v wd 1tb external hard drive, is it possible that the drive is dead can i recover the data.
The electronics in the hard drive is damaged and cannot be repaired by us mortals.
There are companies that can recover data from damaged hard drives BUT it will cost you an arm and a leg for their services.
May 12, 2012 | Western Digital My Book Essential 1TB...
I have a western digital WD1600 WD Caviar SE Serial ATA Hard Drive in my Desktop PC. Yesterday i noticed a loud clicking when i started up, and shut down my PC. Now today when i started my computer i got a...
better to replaced the hard drive, co'z once you heard a loud sound on it, that means that the drive is now having a physical damage, if you the hard drive still working, it will not stay longer due to physical damage inside of the hard drive.
Aug 30, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
How to make my WD 1600 HDD as slave?
There is a small grid of pins near the "data" and "power" connectors on the end of the disk-drive. Look closely; those pins should be labelled:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the small jumper to the 'SL' position.
Connect the power and the data cables.
Oct 31, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
1tb Western Digital hard drive stopped working suddenly, no light
If the hard drive does not even turn on, then check its power supply. Maybe the power supply went bad; it should be a standard 12V 3.5A power supply.
Even if the power supply is working, chances are good that your data are still there, because the unit not turning on means that the internal enclosure, not the disk electronics, got messed up. It's unlikely that BOTH enclosure electronics AND disk electronics went south together, unless you got a lightning strike at short distance (less than 60 feet, say). You'll need to open the enclosure, extract the drive and connect it to another compatible enclosure (most USB/eSATA enclosures with the same EIDE or SATA connector as your WD will do) in order to override the fritzed enclosure electronics and connect directly to the hard disk. Once you do, your data will be there. If the disk crashed last time it turned on, maybe you'll need to run disk checker and expect to lose a file or two.
On the other hand, if the drive does turn on when powered, and the PC "just" doesn't see it, chances are proportionately bad for your data: you'll need to send the disk to a data recovery service, which can be quite costly.
Nov 03, 2009 | Western Digital My Book Essential 1TB...
WD External Hard drive does not work no power to it
External drives tend to use power supplies at 12V DC and 1 amp or just a little bit over. You could read the output of the power supply with a digital volt meter. If you have power and the enclosure still refuses to turn on, you could buy another enclosure, another power supply, or just a naked USB to IDE adapter and pull the drive out of the existing enclosure.
Chances are, the drive you get out of the housing will never be going back into that case.
Jul 11, 2009 | Western Digital External USB 2.0 80 GB...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
POwer supply failure
Hi John,
Had the same problem with a WD Elements 320 GB drive, and found a WD customer service number. They are sending me a FREE replacement. I have put the details on a message somewhere on this site, but can't direct you to it.
The number from Australia is : 1800 429 861 ( routed to Singapore )
Email Address : Western Digital Customer Service . CustomerService@wdc.com
Send them details of your mailing address, drive model and serial number, and a description of your power supply. ( my power supply had a model number moulded on the back )
Hope this helps
Brbull
Dec 15, 2008 | Western Digital Elements powered by WD 320...
Computers & Internet Logo
278 people viewed this question
David Payne
David Payne
