Question about LG Flatron L2320A 23" LCD Monitor
L2300 LG Flatron switching to auto in progress every 5-10seconds
Hi
I have an L2300 LG Flatron that keeps on switching to black screen with "auto in progress" then back to the work I was busy with. Its as if there is a "key" stuck on the monitor. If I press the menu button on the screen can't access any of the options keeps on jumping around to various fields when the menu screen is up.
Any help would be aprreciated.
J
jackboy
  • 2985 Answers
SOURCE: LG Flatron LCD Power Saving Mode
Well thats seems tricky does it not come on at all when you boot the computer. If the screen is working then it should work to display the Start up screen. If it does then keep pressing Delete until the BIOS comes up- then search the pages for power saving and slect to OFF
Posted on May 26, 2007
SOURCE: Analog Out Of range (LG Flatron L1750T)
Install the monitor drivers on the CD that came with it. Most people plug in the monitor and think they don't need the Drivers on the CD. Every thing works fine untill one day you get the problem you guys are having. Make sur you install them manually otherwise windows will still you use the old drivers even though you use the CD
Posted on Feb 20, 2008
  • 415 Answers
SOURCE: screen dead
since it's only 3weeks old as long as you have the receipt take it back .
Mark
Posted on Apr 18, 2009
rj_8017
  • 22 Answers
SOURCE: Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
Posted on Jan 23, 2010
budmrtn
  • 11361 Answers
SOURCE: hi everyone , ive got a LG Flatron monitor model
Check out for bad caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 15, 2010
My Monitor LG Flatron W2243S keeps flickering and turns off, this started yesterday
Try another good monitor, if it solves the problem replace the monitor if not replace the computer.
Oct 25, 2012 | LG Flatron W2243SPF Widescreen LCD Monitor
Hi, I have an LG Flatron L227WTG monitor. I have 2 computers on my desk. When I plug the monitor directly into my home computer, the monitor works just fine. When I plug it into my work laptop (via a...
Hello, maybe you've got to switch the output from your laptop screen to the external screen, if so, it will be by pressing and holding down the Function button and at the same time pressing one of the Function keys (at the top of your keyboard). On mine, (an HP) it's F4, but you'll see a symbol on the correct key that looks like a screen. Regards, nicam49
Jul 13, 2011 | LG 22" FLATRON LCD Monitor
My lg flatron l1753s shows some visual disturbnce like somthing flowing and in few moments shows completely black screen after that normal so......plz tell me what to do to fix it?
It could be the domestic maintenance problem keep your monitor away from moisture and other physical damage it will make your monitor perfect as new working...
Dec 09, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
I am using the LG Flatron L1715S 17" LCD Monitor as an external monitor for my lap top as the screen on my lap top is toast. What I cant figure out is how to size the screen to fit the proper dimensions of...
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
Nov 05, 2009 | LG Flatron L1715S 17" LCD Monitor
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
Black screen on my LG Flatron lcd 563le
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
Bjorn
Jun 02, 2009 | LG Flatron 563LE 15.1" LCD Monitor
LG Flatron L2320A 23" LCD Monitor Logo
104 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
