Question about SanDisk Sansa Clip MP3 Player
My Sansa clip player was hang & shutdown, its not working right now what i do?
I have sansa clip 1gb player. 2 days ago it hang during changing song and immedetly gets off. now its not going on.
  • rjl0906 Oct 17, 2008
    sansa clip only two weeks old will not turn on (yes even when connected to a computer!!)
    Problem Solver:
  • 12 Answers
Your Clip never turns on at all? Even when you plug it into the computer?
Posted on Oct 16, 2008
Mine wasn't turning on, I guess the battery was superlow. I solved it by randomly turning it on and off. Like I held it for 15 seconds, then for 5 seconds, then I tried flicking the on as many times I could in 10 seconds and it turned on briefly but turned off. So plugged it into the USB and it turned on. Hopefully it works after recharging.
Posted on Oct 20, 2008
It got hanged..it can be turned and the buttons are not functioning
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or...
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
Feb 01, 2010 | SanDisk Sansa Clip MP3 Player
How do you put music on the SanDisk Sansa Clip MP3 Player
1. First, you have songs saving in your computer.
2. You have 2 ways to put music on the Sandisk Sansa Clip:
2.1. Plug device into computer, Drag and Drop music from your computer into "Music" folder of the Sandisk Sansa Clip.
2.2. Use Windows Media Player in your computer to transfer songs to your device; Plug device to computer, open Windows Media Player, click on Sync tab, drag and drop music into "Drag items here " on the right side of the windows media player, click on Start Sync button.
Good luck
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip 2GB MP3 player won't let me add any more songs to it, even though there's 1.26 GB still available. I don't want to reformat the player, cuz that'll delete the songs I already have on there. ...
Hi there..
When you say having difficulty in adding the songs in CLIP, though you have enough space. I'd kindly request you to check for the number of songs that you have added.
Because when you add as MP3 player by default its bit rate is 128kbps so you can add up to 500 songs only. Kindly have a check on it.
I have given the number of songs that can be added with related to size of MP3 player..
Size of the player :512MB 1GB 2GB 4GB 8GB 16GB 32GB
Number of songs : 125 250 500 1000 2000 4000 8000
Kindly revert if any clarifications....
Jan 30, 2010 | SanDisk Sansa Clip MP3 Player
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
I just got a sansa clip 1gb mp3 player & need help on everything!
The Sansa Clip is not compatible with iTunes. You will have to get your music from another music service, preferably one that gives you the songs in mp3 format instead of AAC format (although it will accept WMA's, the DRM-protection system on most WMA's will give you problems down the line, especially if you cancel the music service that you got them from - songs in mp3 format will be usable even after you've cancelled your music service subscription).
-Tha Mp3 Doctor
Mar 03, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Sansa clip mp3 1GB problems
the best way to solve the problem is to return it to the store! let the sudisk solve the problem and only after that to sale them
Mar 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player
To help you with that, I need to know what operating system your using (XP, Vista, ect...) and what other devices you have plugged into the computer. There are a few things you can try. When you plug it in, does it say it's connected? Does the "Found new hardware" wizard come up? Let me know, I'll see what I can do to help
Dec 31, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
100 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
