Question about Sony Handycam CCD-TRV68 Camcorder
Rolling of picture
I bought it in Dubai. Now I am in Canada. When I am trying to play in TV, picture is unstable/ rolling. In camcorder play looks perfectly ok. I believe some system is not matching with Canada TV & handycam from Dubai. Pls suggest 1990 Sony VCR, Video 8 tapes. Mono viewfinder. Colour recording.  PROBLEM: Picture in viewer is fine on playback all the time, but output image is unstable - sometimes! This is true using either output to aerial input on TV, or SCART connection.  Newly recorded material is fine as far as I can tell, but only short test recordings made. Material from a few years ago tends to be unstable from time to time. When it is unstable it seems to drift from slightly unstable to very unstable and back, and from B/W to colour over about 3 second intervals. It seems like tracking, but can't be as viewfinder is always fine (B/W viewfinder) What part of the playback/output circuit might be at fault?  Actual model is PAL Sony CCD TR45E. Thanks a lot fort any pointers you can come up with.
I have a Handycam Video 8 CCD AF camera. I bought it in about 1993. The picture I'm getting is very fragmented, jumpy, and for them most part lacking color. I can barely see the images because of all the jumpiness. How do I fix this???
Posted on Dec 23, 2009
  • 10,594 Answers
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Posted on Oct 04, 2008
Rolling, Shaky picture
My best guess would be the video adapter switch you have to use to hook up the game console to the TV. If I remember correctly you have to slide a switch to either TV or game depending on whether you are watching TV or playing a game. Over time switches like that need the internal contacts cleaned. You can probably get a can of contact cleaning spray at Radio Shack. Just follow the directions on the can of contact clearer and you will probably fix your problem.
Feb 15, 2014 | Atari 2600 Console
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
LCD screen continues rolling
There is connecting ribbon wire between LCD board and main camera board, this ribbon wire is cracked and needs to be replaced.
Dec 10, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Rolling of picture
It seems your Handycam has " Pal " system and you are watching it on " NTSC " TV. If your TV is Multi Color System, please select Pal color system. Hope this info will be helpful for you.
Aug 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
Sony Handycam CCD-TRV68 Camcorder Logo
347 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
