Question about Ovens
Blomberg BEP 906. After power went out a couple
Blomberg BEP 906. After power went out a couple of times, it now behaves completely erratic. Not possible to regilate temperature, display shows random elements (does not resemble numbers or letters). Nothing works anymore.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Does anybody have manual for Blomberg BEP 906?
Posted on Jul 15, 2016
    Genius:
  • 1,417 Answers
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Posted on Dec 29, 2011
  • Nils Ole Backstrom Dec 30, 2011
    Read the description before answering, the description specifically says: "Not possible to regulate temperature", so this solution is no solution at all!!!!!
    Just noticed the comment about the "bake" button, you obviously don't know anything about this owen, as there is no "bake" button on it.
SOURCE:
Why is ignition and/or clock blowing the mains fuse?
Oh dear. Water damage is not easy to repair. Strip the electrics down and replace the damaged items.
Nov 22, 2014 | Ovens
Blomberg mkn54322 not working
www.blombergappliances.us
Jun 23, 2014 | Ovens
GE Profile Oven temperature varies wildly
What is the model number of your unit?
Nov 19, 2012 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
Dec 16, 2010 | Ovens
Users manual for simpson evolution 906 fan forced oven
my lovely wife just put the grill on for 5 mins with the door closed and the inside glass went bang, where can i get a manual for this oven ???
Dec 12, 2010 | Ovens
Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Jun 28, 2010 | Ovens
Ovens Logo
381 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
