Question about Acer Computers & Internet
HI I had my computer converted to windows xp two months ago and the tech forget to put my sound card back so i have no sound,so my question is how do i get a sound card regards rosemarie hull
  • 2 more comments
  • beauhull Oct 04, 2008
    hi fixya
    the model is aspire5310 and i need a new sound card as i don"t have
    regards
    rosemarie
    hi scott
    thank you for you advice if i could get hold of the tech i would give him a mouthful but he won't answer the phone.Oki have the model isJDW50and i dont know if this the serial no 73202579816.I don"t need anything fancy as i only need a sound card for my dvd
    and cd"s
    regards
    rosemarie
    thank you for all you did for me.this is my first computer and i am still learning it is nice that someone listens. i have had the run around for three days so i am so pleased to finally have my sound.card(THANK YOU ALL)
    Rosemarie Hull
  • beauhull Oct 05, 2008
    HI guys from fixya
    Thank you again for your solution i now have SOUND and you don"know how good it sounds So much for all the software i brought along the way telling me that it will fix the problem.So thank you again if i come across another problem i will contact you
    Rosemarie Hull
    Genius:
  • Acer Master
  • 1,250 Answers
Go to the bios and check whether the sound is enable or not if it is enable then install the drivers
Posted on Oct 04, 2008
  • Acer Master
  • 1,879 Answers
Look at the back of your computer and locate a GREEN, PINK and BLUE stereo jacks. this just to check if you really don't have a sound card. all branded computers nowadays have an embedded sound card on the motherboard.
    Sergeant:
    Champion:
  • 200 Answers
Hi
You can download the driver from this site
http://www.10001downloads.com/s/acer-aspire-5310-driver.html
thank you
    Sergeant:
    Champion:
  • 214 Answers
Visit the acer website and download the audio driver providing the model no. and then install it
    Novelist:
  • 169 Answers
Rosemarie-
First, I would contact the tech and find out if they still have the card. If not (after giving them an earful), find out if they are willing to make amends by replacing it (that's the least they can do!).
Regardless, if you still end up buying a sound card, there are many many brands and types on the market. If you just need good clean audio and don't need anything fancy, stick with the lower end. Creative Labs makes a nice card, as does Turtle Beach. The fancier you get, the more expensive it will get, so remember that.
I'm not sure what style card you would need, but the most popular format for "standard" computers is PCI. If you can send your system's serial number I can verify that's what you have.
NOTE: some types of hardware require you install the software FIRST, then the hardware. Some are just the opposite. When in doubt, check the manual/installation instructions before opening the computer.
Assuming you install the hardware first, actually installing the card is pretty simple as well. Open the case, and look down. (Assuming PCI was correct), you'll see several white/creme colored "slots' that look like this:
HI
If you'll notice, there is a 'notch" in each of the slots. This prevents you from putting the card in any other way than correctly, as the corresponding notch is also on your card.
First and foremost, when handling the card, always try to keep grounded by keeping a hand, finger, some body part in contact with the metal case. You won't shock yourself, but you will do is prevent ESD (electrostatic discharge) from "frying" your card before you even get to enjoy it. Important!
Locate the empty slot that your previous sound car was in, and use that one. The metal cover that was removed originally should still be gone, so you won't have to remove it again. If you hold your sound card over the slot (what I call "eyeballing" it), you should be able to line the notch up with your sound card and just slide it in vertically. Put even pressure on both sides so it goes in smoothly.
Once installed all the way into the slot, as far as you can get it, line up the hold on the card's bracket with the screw hole on the case and insert the screw. This will secure the card to your motherboard, and to the case.
Replace any panels you had to remove and go ahead and plug everything back in, most importantly your speakers to the input channel on your sound card. It's usually green/light green or even blue, but most of the time it's some shade of green. That's where your speakers connect.
Reboot your machine and Windows should detect a new device. If you have a different card than before, you will need to install software drivers, which will have come on CD. Follow the instructions to install, and afterwards (and a possible reboot) you should havd working sound again!
I hope this helps - please don't hesitate to ask if you have additional questions :)
Scott
    Genius:
  • 1,550 Answers
You need to provide some more details regarding your computer such as model number .
Do you need a new sound card or a sound card already present but not installed properly?
  • SAM ANDERSON Oct 04, 2008
    You dont need new sound card for your model . Also you cant install sound card on it . Only thing you can try is reinstalling the driver . Click the link below to get files for your model
    Driver files for Acer 5310
  • Acer Master
  • 19,396 Answers
You need to install audioo driver, give us computer model to proceed, if your computer is assembled you may need to read motherboard model number from inside the computer.
  • Ginko
    Ginko Oct 04, 2008
    Hi Rosemary, if the computer is an Ager, give me computer model number, and I should be able to find driver download for your model.
    Sure the technician did not do his job properly, after installing the system, he was supposed to install drivers for all integrated devices.
  • Ginko
    Ginko Oct 04, 2008
    You do not need a new sound card, as Aspire 5310 is a laptop, you cannot even install a sound card on it.
    All you need is the driver download to reinstall driver software. The problem is that Acer did not release any driver for your laptop, as the laptop had been built for Vista only. As you can see on download page here, the only driver available is for Vista.
    The computer repairer should have checked XP compatibility before downgrading and doing a bad job.
    Try downloading the software from here: Realtek Audio
    You will need to unzip the file after downloading, then you find the unzipped folder and run the file called setup.exe.
    Here you find the rest of the drivers for XP on your laptop.
Emachine sound card
GO TO SERVICES AND RESTART WINDOWS AUDIO.
http://www.innovative-sol.com/drivermax/
DRIVERPROGRAM.DO A SCAN.MAYBE YOU GOT WRONG DRIVER.
Oct 02, 2013 | Computers & Internet
Card installation
1) Turn the computer on. When Windows has loaded all the way, put the Installation (CD) disk in your optical drive. Load the software.
No disk? Go to the Sound Card manufacturers website, and download the software. Now INSTALL it.
If asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off.
FOLLOWING Anti-Static Precautions, and computer unplugged from power, open the computer case, and physically install the Sound Card.
Close the computer case, do not forget to hook up the audio wires to your sound card.
Plug computer into power, WAIT 1 minute, turn the computer on.
2) Doesn't have a sound adapter card, and is just Integrated Audio?
Download AND install the audio drivers from Asus for that motherboard, AND Operating System you are using.
(Win XP and Win 7, are two examples of an O/S)
Need further guidance than this?
Post the Sound Card manufacturer and Model Number.
Also post the model number of the Asus motherboard.
Post in a Comment.
Regards,
joecoolvette
Sep 03, 2012 | ASUS Computers & Internet
Hi, please help me! i have a JVC HD everio purchased 6 months ago, and i cannot for the life of me figure out how to put my footage onto DVD, or computer then DVD, without taking it to a camera place and...
Your camera has a removable SD card in it to record your video. If your computer has a card reader built in the you simply insert the SD card from the camera to the reader and transfer the files to your PC. If your PC doesn't have a reader, they can be purchased on line or Walmart or any camera supply store for anywhere from 3 to 6 or more dollars.
Jul 28, 2017 | JVC Everio GZ-HM650 Camcorder
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
I just got a pair of Logitech LS21 2.1 speakers with a subwoofer for my Acer Aspire 3680. A couple months ago, I reformatted my computer & put Windows XP with Realtek HD Audio system on it. When I...
Depending on the software that runs the sound card (you can find it in the control panel), the ports may be configured differently than they used to be. Check in the control panel and see if there is way to adjust the "plugs" and what they mean. Some of the sound cards allow you to change your mic to a sub and your input to an output!
Jul 07, 2009 | Audio Players & Recorders
Sound card drivers
most drivers are available at:
http://drivers.myfreewares.com
When you provide more info, I can be more specific.
Oct 25, 2008 | Computers & Internet
Computer has no sound card
Hi rosemarie, as I said, you need to tell us the model number, so that we can address you to the right download.
Oct 04, 2008 | Computers & Internet
I have got a hp pavilion dv 5000 i bught it 16 months ago with windows xp on it but i have put windows vista on it now i dont want vista do you have a restore disk to wipe off vista so i can have xp back...
Hi Harrison685,
Thanks for posting in FixYa.
Sorry Window Xp can not be retrieve back by restoring. You need to Reinstall it. Please use your Window XP Installation Disk for this.
Regards
ELLIN
Sep 16, 2008 | HP Computers & Internet
Change vista to xp on acer laptop
see if there are any drivers in XP for this model to start- if there are not- you are NOT able to convert it back to XP at ALL. Check with acer's tech support to see if it is possible to get drivers or if it is possible to convert it back to xp. Good luck- I'm seeing this problem a lot at the moment and the manufacturers do not care about people that hate vista.
Nov 28, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
