Question about Pioneer Audio Players & Recorders
I have a Pioneer SA_410 Amplifier. Has open circuit mains transformer. Could you advise what its AC secondary output voltage & current are? Regards
  • 142 Answers
I have replaced many thermal fuses in power transformers. Is the primary open?? If so, cut the copper shield on the primary side of the transformer with a pair of cutters and peel back the paper insulation to reveal the thermal fuse. Replace it and everythings OK!! If the secondary is bad there's no hope, of course. Anyway, in the meantime I will research your question and post again very soon. I have several old pioneer schematics and know where to find what I need.
Posted on Oct 04, 2008
Conventional power pack
A primary and secondary usually refers to a transformer. The primary side being the input side 110 AC Volt or 220 Volt AC side. Also called Source.
The Secondary being the "output to load" side 12 Volts "for example". And also called Tap (Secondary Tap)
The voltage is changed by conduction, magnetic flux, neither side touching one another. And the number of turns of wire, per side, determine the voltage. The voltage may either be a step-down or Step-up depending on its use.
An unconventional method is to have both the primary & secondary combined into a single tapped winding - which arrangement is called an autotransformer. The autotransformer does not provide isolation between primary and secondary circuits but its simplicity makes it economical and space-saving.
Imagine a single wire wrapped from the top to the bottom being the primary, and tapping in. in the middle and bottom for the secondary, so the output becomes 1/2. That would be a step-down transformer.
The actual measurement of a transformer is measured by its efficiency (Faraday Law) which is defined as a ratio of power. I hope that's sufficient, but if you want more I would buy for $2 bucks an Electricity Made Simple Book, because there are pages after pages to write about transformers, and to understand electricity in general it is helpful to understand the difference between alternating current and direct current and its magnetic field of induction and magnitude of emf.
May 10, 2014 | Cars & Trucks
Schematic malibu 8100-9120-01
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
May 09, 2014 | Intermatic Malibu 300W Power Pack...
Need service manual for pioneer sa-600
Head straight to the (European) electrotanya website, which offers free downloads of a wide range of service manuals. No registration is required either.
The Pioneer SA-600 schematic shows both voltages and currents. For this amp, the total current for left & right output modules (no signal) is 60mA. No-load voltage is 58 volts, dropping to 48 volts (one channel driven, 25 watts out).
PIONEER SA 600 SCH Service Manual free download schematics eeprom...
Feb 26, 2014 | Cameras
Pioneer model SA 9500 stereo amplifier problems.
Is the dc voltage reading on the base of the outputs 0.6 with emitters reading 0.014 or there about. Depending on the outputs used you might read 1.2volts on the base. Your collectors will read the power supply voltage of 50 or 60volts or more. If this is what you are reading on your meter the problem is in the speaker protection circuit. This circuit is what drives the relay you tested.
Jun 27, 2012 | Pioneer Audio Players & Recorders
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Does anybody have a schematic for the Behringer LPA1300 power amp section used in the K3000FX keyboard combo? Are the output devices supposed to be the ground path for the power amp. (there are no...
Look at this one:
This is for the 1800 however...
Often they will just double up with two amps, one inverted, and use in bridged the higher power in what we call an "H" arrangement.
Since the drains are tied together, the heatsinks MIGHT be hot output level.
Feb 05, 2011 | Behringer Ultratone K3000fx 300w Keyboard...
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Amp power
Make shure with an ohm meter that the primary and secondary windings have very little resistance on the main trasformer,then check voltage in trasformer and out from transformer...BIGRED
Sep 02, 2007 | Audio Players & Recorders
104 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
