Where do you put the lead from the speakers to your pc?
  • 1,879 Answers
To the green hole
pink for mic
blue for other audio input
Posted on Oct 04, 2008
Speakers will not work on e machine et1331g but are installed
Hi,Dear User..Flow instruction:-
1> Check you speaker all connection point.2> Check you connect speaker lead out put Point.3> Power point Check to speaker.4> Installed Audio driver to mother board. Not any other Driver install only proper driver.5> If driver install then check it. a> Go to control panel- Add or remove program, hear show audio driver or not. if not show then install.
b> My computer right click- property- hardware- device manager, if audio point yellow then install driver. if not yellow then install driver.
6> If all thing check then you speaker not support in you PC.
Note:- Batter then Contact good Computer Hardware Engineer.
More Computer Support.
Thanks...
Feb 13, 2013 | E-Machines eMachines Desktop PC
Everytime i put a new fuse into my amp the fuses fry instantly.
the fuse is frying instantley because you have a direct short. have you tryed disconnecting the speaker leads from the amplifyer? if disconnecting the speaker leads works then you had a short in your speaker or speaker wire.
Aug 16, 2011 | Scosche Industries Scosche High...
Do i need the speaker out lead 2 use it??
ever computer speaker has a cord for connecting it to the pc. in most cases just a single cord does the trick (you do not need the out 2 lead to use it) unless it is a sophisticated speaker such as one for studios.
good luck
Jul 04, 2010 | Altec Lansing ACS 295 Computer Speakers
Dimension 8400 PC Desktop: Where do I connect the monitor mounted speakers to...
you connect the monitor's speaker lead to the speaker jack or line out jack on the sound card.
May 03, 2010 | Computers & Internet
How to hook up a pc computer
power lead
monitor lead
mouse lead
keyboard lead
are the ones that you must have. Optional are speaker, microphone, ethernet/internet, and telephone.
Nov 21, 2009 | HP Compaq Presario dv6693us Notebook
How to wire 2 opti1533d by lanzar with the optidrive 2000d amp? how do i wire them if i put 1 amp on each sub
your speakers are 1 ohm per voice coil, dual oice coil. your amp is no lower than 2 ohms stable mono.
the proper way to wire this so that you do not burn out the amp is to run the 2 vioce coils in series. run the positive lead from the amp into the positive lead of one of the voice coils, then run a jumper wire from the same voice coil's negative lead to the same speaker's 2nd voice coil's positive input. then run from the 2nd voice coil's negative back to the amplifier's negative speaker lead.
you will be running for each speaker/amplifier set: amp + to terminal set 1 +, terminal set 1 - to terminal set 2 +, then terminal set 2 - to amp -
Oct 06, 2009 | Car Audio & Video
I just bot Pioneer speaker CH26861...4 wires to 2 leads...
I would tie both + from the speakers to the radio, and both - as well. This will give an equal amount of power to both speakers and reduce the chance of blowing a speaker. As for +&- on the speakers, It is usually marked on the black piece right by the terminals. As little power as you are putting to the speakers, it doesn't really matter which way you hook them up, as long as they are both hooked up the same.
Jul 30, 2009 | Car Audio & Video
WANT TO KNOW WHERE TO PUT MY AUDIO LEADS BACK IN THERE PINS ON THE MOTHERBOARD
Mic In to pin 1; Gnd to pins 2 and 3; R Out to pin 5; Ret R to pin 6; L Out to pin 9, and Ret L to pin 10. Remove the jumpers on pins on the motherboard before placing thses wires.
If it is an internal speaker connection
SPK1: Internal speaker header Pin Signal Name
1 SPKR
2 NC
3 Ground
4 +5V
Hope this helps
May 09, 2009 | Computers & Internet
SOUND OUT OF 2 SPEAKERS ONLY
Hi there
have you went to sounds and clicked on the speakers and scrolled down to the surround sound or the quadraponic setting, and also by changing to different speaker advanced settings you should be able to get the other speakers working ok
best regards mike
Mar 23, 2009 | Creative Labs Inspire 4400 Computer...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
