Question about JVC Televison & Video
JVC InteriArt 32 inch conventional TV 3 years old- no warranty. TV is switching off and coming back on every 57 secs. Lose about two to three seconds sound and vision. Checked to see if sleep timer was set. It was off. One suggestion is that microprocessor is at fault and very expensive to repair. One suggestion is to switch off set at socket rather than on/off switch for 4 hours or overnight to reset software. Will try that tonight. Any other suggestions other than give it a whack to see if can reconnect dry joints/loose connection?
    Top Expert:
  • JVC Master
  • 75,032 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on May 08, 2017
  • 2326 Answers
SOURCE: Thomson 27LCDB03B
If all the voltages measure normal, the failure could be in the LCD's inverter board. I've checked the schematic and it seems like the 16 volts could be a bit higher, check the electrolytic capacitors filtering the voltage for the inverter board.
Click here to download the service manual.
Good Luck.
Posted on Sep 12, 2008
  • 67 Answers
SOURCE: double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Posted on Dec 30, 2008
  • 8617 Answers
SOURCE: My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
Posted on May 11, 2009
  • 8617 Answers
SOURCE: blinking timer light
The blinking timer light is usually caused by bad capacitors on the DM board. The V26 DM repair kit from should repair that issue. The kit contains the parts and the Cd with instructions.
Posted on Dec 20, 2009
  • 3459 Answers
SOURCE: Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
Jvc interiart musee 25
I'd personally look at getting it replaced either through a warranty claim or new purchase
Jul 24, 2014 | Televison & Video
Jvc interiart television
hook up box to a stereo thur av jacks if it dod it thur stereo then its not your tv its your sky
Sep 19, 2013 | Televison & Video
Where is transformer located in jvc interiart tv model no av-28x4sr when i turn on tv the power light comes on but the screan stays blank and a clicking noise comes from back of tv the tv is about four...
good day your tv has no transformer.the subtitute of transformer is avr or automatic voltage regulator. maybe your tv has a defect,either flyback transformer or the main board. has a shorted parts.
Jun 21, 2010 | Televison & Video
Current value of a jvc 32 inch color tv 8 years old
The street value would be 100-150 dollars. If TV is a cheap model or abused or very used, you should pay less.
Consider a Sony or a Toshiba in tube style since all are cheap now.
Sep 27, 2009 | JVC AV-27D302 27" TV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
JVC InteriArt TV switches off after 4 seconds! help!
There might be something wrong with your TV Set power supply. I guess it switches off because of damage to all the electronics prevention. You should call to you local repair service or if it is still hasn't expired the warranty, call the warranty service
Jan 23, 2009 | Televison & Video
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
JVC AV-32750
Resolder the vertical deflection output IC421. It is located about three inches to the left of the flyback transformer which is the part with the red cable going to the picture tube.
Nov 12, 2007 | JVC AV-32750 32" TV
JVC AV-32FA44 32" - No Picture, but sound OK
You could have a power supply problem as parts do go bad. Why your set faile is a mystery.. Of course if your not a technician, a TV set is NO place to be experimenting with. It only about a year old you say But get the papers on this set if you can find them and make sure as there is a 12 month warranty on this model. You should contact JVC At 1-800-252-5722 or online at Good Luck
Aug 07, 2006 | JVC AV-32FA44 32" TV
Televison & Video Logo
127 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
