I have a Stanton T.80 and Vestax VMC-185XL mixer. I recently bought Rane Serato Scratch Live which requires the turntables to be grounded through the mixer...however, the turntable doesnt have a ground wire nor can i find an internal grounding switch. The sound through the Serato is humming despite careful and accurate setup...it appears the grounding is the problem...What do I do? Thanks
  • gium_13 Oct 04, 2008
    hi...thanks...in the end i made my own grounding wire, attaching it to mixer and turntable chassis...it helped a bit but not much...the problem was the level...i switched to line and it fixed it immediately...guess its due to the digital nature of using software on laptop to play rather than just turntable/mixer setup
    cheers
  • 1,512 Answers
Hi gium
Sounds like we have reached that point where progressive crossover in technologies means that the usual cautions of earth continuity for the tone arm when using a phono preamp has gone the same way as phono preamps on home theatre.
Have you tried switching to the line level and set the mixer up for that level also. That may reduce any gain induced hum. However it sounds like an earth loop problem, where both decks will need to be earthed in the mixer. Check also that all the gear is running of the same power point. Different mains phases are sometimes available near each other, having any gear (power amps also) on a different phase will cause an earth loop problem.
Is the hum all the time independent of the volume levels, or change with levels adjustments and not at all when turned right down. Let me if changing to line levels helps. We can try some more things, like connecting a temp hookup wire earth to the RCA earth to mixer chassis. Cheers
regards
robotek
Posted on Oct 04, 2008
Serato does not recognise my technics turntable. The turntable is on and turning well but no response from serato. the arms in the serato do not move...help?
serato is a software to be used with an external soundcard it doesnt care what turntables you have. u have to a rane mixer or one that is serato capable in order to use it. then you have to go and link and sync your time codes
May 26, 2011 | Technics SL-1200M3D Turntable
Why does this not work?
hi i am using a sahara notebook but thair driver are not installed even i dont know the model no how i can solved the problem which driver is the best for my notebook will you plz help me
Jul 13, 2009 | Rane Serato Scratch Live Computer DJ...
My comp cANT SEE serato scratch live
You have to hook up the SL1 Box or the 57SL mixer and then install the drivers. If you are not hooked up to either of these it will say 'Interface Disconnected' or 'Soundcard Not Found'.
Mar 24, 2009 | Rane Serato Scratch Live Computer DJ...
Turntable Crackling
sounds to me like your fader has popped! lube contact spray will not solve the problem, it will only clear it up for a few passes if any! PCV faders have covers inside which stop any lube getting right on the contacts! but in my experience as a scratch dj for 11 years is that contact spray only make the problem worse over time! best shot from here is to replace the fader, or get a mixer with optical/contactless fader i suggest a mixer with the 'eternal' fader i.e. ecler 360/80hak. hope this helps
Feb 03, 2009 | Technics SL-1210 Turntable
Using other sound cards with serato scratch live
Using pc onboard sound cards with serato scratch live
Jun 08, 2008 | Rane Serato Scratch Live Computer DJ...
253 people viewed this question
 Grubhead
Grubhead
