Question about Zebra TLP 2844-Z Thermal Label Printer
Not Printing Hi, My TLP 2844 just spits out empty labels when I ask it to print. I am using Bar-One 6.0 Lite.and matt labels 2 x across. I am using it in Thermal Direct Mode and have already altered various settings to see if this helps with no luck. It is attached to LTP-1. The label was originally designed to work on a TLP 2824, but I want to be able to use this on either printer. (different locations, same laptop)
  • 45 Answers
SOURCE: Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Posted on Sep 20, 2008
SOURCE: TLP 2844 skips over labels
I've had this same problem on the TLP2844. We are using 3 x 1 labels to print shelf barcode labels, it prints a few then skips some labels then prints more. The number printed and skipped are not always the same.
What I did was recalibrate the printer. Turn the printer off. Hold Feed button and turn printer on. The printer will begin feeding labels, looking for the gaps. After the calibration is complete a configuration page will print. Press Feed after to return to normal mode.
Hope this helps.
Jason
Posted on Dec 19, 2008
SOURCE: TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Posted on Aug 17, 2009
  • 62 Answers
SOURCE: Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
Posted on Nov 20, 2009
  • 185 Answers
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
Posted on Dec 20, 2009
I'm using ZebraDesigner and trying to print on a TLP 2844 printer, but it keeps printing across labels.
This reply is a bit late but for anyone else having this problem, you need to select the right orientation in your printer preferences in your software and in the printer driver, If you still have problems contact www.lancerlabels.co.uk
Home
Sep 17, 2014 | Zebra TLP 2844 Thermal Label Printer
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
Zebra printer 2844: prints one label and spits out several empty labels and stops midpoint of a label. To print again, I must correct the label position, turn off then on. Cannot get dump to...
If you are using a windows system please go into the control panel by clicking the start button and choosing control panel. In the control panel go into the printers, right click on the label printer,choose printer properties and then click the tab labeled printing preferences. Choose the page setup tab and please let me know the size that is specified next to the name.
-Kyle
Sep 16, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Loftware labels printing off staggered.
Most reasons for this is a slight adjustment problem with page length. You can recalibrate the printer via the menu system, doing it this way will adjust the sensors with new settings
Mar 11, 2010 | Zebra Eltron TLP 2844 Thermal Label...
I have TLP 2844 its printing very poor quality
Download zebra setup utility and use it to configure print quality.
Sep 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
52 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
