Question about MSI MS-6390 (-6390-010) Motherboard
No display with AGP card
When I plug an AGP card in, I get no display from the onboard outlet and only vertical stripes from the card socket.
Do I have to disable the onboard first?
Please help
I had a similar problem , i changed a setting in the bios.
if you know how to get into and around the bios menus then you may find the relevant setting , i
hope this helps
Posted on May 15, 2009
Re Instal the video Card
that what i thinksss
Posted on Oct 14, 2008
MA-516 TEC motherboard
do you have onboard video or an add in AGP / PCIe video card
Jan 22, 2013 | Computers & Internet
Shuttle mv43v v7.3 AGP card won't work
Go in the BIOS and disable the onboard video.
Feb 03, 2010 | Shuttle MV43VN Motherboard
Wie disabled man die onboard-graphic? Ich möchte eine Radeon X1600 mit 512 MB in den AGP-Slot einsetzen. How disabled the onboard-Graphic? I want use a Radeon X1600 in the AGP-Slot
Just plug in the Radeon video card in the agp slot and the system will automatically detect the new video card and disable the onboard-graphics.
Oct 30, 2009 | Computers & Internet
NO VIDEO
Are you using the onboard video or a display card adaptor?
1. If you are using the onboard video then try installing a known working PCI or AGP display card to test if the problem is onboard video or the actual motherboard.
2. If you are using a display card then try another known working display card (PCI or AGP) to test whether it's your displaycard that is faulty.
3. If it still doen't work then try removing your memory modules on the motherboard and replace them with known working memory.
4. If it still doesn't work then try removing your CPU and reinserting it again (be carefull as you do not want to damage your CPU!).
5. If it is still not working then you may need to replace your motherboard or take your PC into a repair facility.
Thanks
C
Apr 03, 2009 | Cornerstone FIC AM37-L Socket A XP...
Vedio controller
Your AGP (Advanced Graphics Port) slot is a Video Card Slot on *********** Board... It is usually a brown slot this is above the PCI (white slots). You have to have a Video Adapter ( video card ) for your PC to display ANYTHING, so you either have a card or you have onboard video which shared some of your system RAM for Video. This card is where you plug in your monitor, so if your monitor plugs into a seperate card then you probably have an AGP card, if it plugs in near the mouse/kb/sound then it is most likely an onboard video adapter.
Dec 18, 2008 | Computers & Internet
No display with ASUS M2N-E Motherboard
Repeat the procedures you learned , the exact same procedures apply to all situations
With certan motherboards you may still not see any video output
Which may mean an incompatability with the motherboard or defect
My advice is to plug in a CRT to the primary video port as a first step to getting video
Primary video port can also be the onboard video
Once you've got video you can begin the process of shutting down the onboard video and inserting
your new video card , with some motherboards if the person adds a new agp video card the system will automaticaly shut down the onboard video and use the new agp video card
BEFORE adding a new AGP video card
Don't forget to install ALL of your Microsoft Windows Critical Updates and Service Packs
because they will contain information and files that some computers require in order to function
properly with Nvidia Graphics Cards
That is especialy true of the FIC nforce2 motherboard.
You're in the zone.
Shalom >:D<
Sep 14, 2008 | Computers & Internet
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Stripy Boot Up
is it a new graphic card? Sometimes that happens when the graphic card gets overheated and fries up some chips. and sometimes those lines appear when the graphic card has fault in Direct Draw. Try setting your BIOS settings to default. if it doesn't work, i recommend you to take the graphic card to the nearest hardware tech ;)
Oct 16, 2007 | SPARKLE Computer GeForce 6600GT, (128 MB)...
I cannot install an agp graphics card
you will have to dissable onboard graphics in the bios, or remove any other AGP card graphic card drivers that have been installed first.
Sep 19, 2007 | Mercury Electronics KT266A Motherboard
MSI MS-6390 (-6390-010) Motherboard Logo
152 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
