Question about Nokia 6030 Cellular Phone
Screen problem nothing seen on screen despite blue and black line only. I can receive and call but not see the number.
    Problem Solver:
  • 10 Answers
Change it's lcd...... r check u'r lcd connector
Posted on Oct 04, 2008
Have line on the top black vertical line not so clear but its not normal
Please check if the problem can be seen in the BIOS screen. - you can go to the BIOS screen by tapping F2 repeatedly as soon as you turn on the computer.
If the vertical line can be seen in the BIOS screen, it is already a problem with the LCD screen and you need to contact the computer manufacturer for possible LCD replacement if your computer is still in warranty.
Hope it helps you.
Apr 17, 2011 | Toshiba NB305-N410BL 10.1 inch Mini...
Sony KP 51 HW 40 Blue Lines
Some of these sets had problems with bad picture tubes; there is something you can do to try to correct this without replacing any parts.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You may have a bad blue picture tube but there is a way to deal with this first----the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input clip_image001.gif with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
I do this here for free so if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 01, 2009 | Sony KP-51HW40 51" Rear Projection...
BLUE SCREEN WITH FAINT CURVED TRACE LINES
I am the one who wrote that solution--this varies a little from model to model but here is the basic:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SONY WITH BLUE SCREEN PROBLEM:
I do this here for free so if this has helped you take a moment and give me a vote here.
SD TECH
Nov 14, 2009 | Sony KP-51WS500 51" Rear Projection...
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Thick Black Line on Screen
This is caused by dead pixel sensors. There are hundreds of pixel sensors at the edges of the screen, when they go out it will cause a line varying in size depending on the amount of sensors that go out, and the line can vary in color, red, blue, green, white, and black. Unfortunately, the only fix for this is to replace the screen.
Jul 30, 2008 | Computers & Internet
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Blue screen Freeze!
perhaps your OS has died................one thing is sure ..... your display is ok u have an OS problem
Jul 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Screen now showing blue line at bottom
Sounds like, you have a bad optical block. Part can cost $550 to $800 + labor
Mar 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Nokia 6030 Cellular Phone Logo
46 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
