Question about Dell Precision M60 Notebook
Blank screen with cycling colours (no BIOS; no POST)
I've got a Dell Precision M60 Laptop which was working fine till now. When I start it up, the screen is blank at first (and it doesn't even enter BIOS POST). Then the whole screen changes to grey, then red, green, black, and keeps cycling. The CURSOR does not show up at any point in time.
If I press the Fn key when I start it up, then the NumLock key is FLASHING, CapsLock is ON and ScrollLock is FLASHING. Again, the CURSOR does not show up at any point in time.
I've already tried removing the 2 memory modules in it and swapping them among the memory bays, using only one at a time in each bay, etc... The modules are fine because I checked them on another laptop.
Occasionally, it happens that when I start it up, the screen is black and the cursor is blinking at the top left but no other activity (does not enter BIOS/POST).
Can you please help me with this strange problem.
Thanks in advance for your time!!
Cheers
    Scholar:
  • 155 Answers
Try running diagnostics. Tap F12 repeatedly on the dell logo till you get the boot device menu. Choose diagnostics. Go through it.
If it doesnt even pull up the diagnostics, you can follow this walkthrough from dell's website.
Posted on Oct 04, 2008
  • Rachelle Aviles
    Rachelle Aviles Oct 04, 2008
    The flashing-on-flashing code that you get when you start it up, indicates a possible LCD failure. Hope you don't need to replace your LCD but it may be the case. It may not be helpful, but you can try to reseat the lcd cable. You can call dell so they can walk you through it.
    LCD replacement can be done through dell's depot which for me is costly. Or you can contact their spare parts dept. to purchase the part. You can find a local technician to install it.
  • Bastian Farkash
    Bastian Farkash May 01, 2013
    Yes, faulty Hardware problem is what I am suspecting as in something serious enough to stop it from running the POST.
Reset the bios password for a dell precision m60 laptop
the reason they have a password is to secure the data. In order to reset the password you have to know the old one. The only way I know to get around it, is to use the restore disk which will let you set a new password or no password but most data is lost unless you have a back up.
Feb 02, 2015 | Dell Precision M60 Notebook
How to reset Dell Precision M60 BIOS password
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 06, 2010 | Dell Precision M60 Notebook
Precision m60 power not staying on
hi first check addopter if power work fine then check ram if ok check proccessor if ok press main chip on board then check shortage may bee any fet or capceters shorts
Jul 18, 2010 | Dell Precision M60 Notebook
Dell inspiron laptop screen colours inverted (negative)
if the same issue occurs in the BIOS your soluton is to have your LCD screnn replace or have your LCD inverte cable checked/replaced ^_^ this has nothing to do with the BIOS vodeo card drivers do not function in the BIOS to be able to do such in the BIOS screen
Jun 04, 2010 | Dell Inspiron E1705 (DNDWGA3) PC Notebook
I have upgraded my Dell Precision M60 to Windows7 OS. audio glitches during play back. how do i solve this issue.
well download the driver for windows 7 compatible from the dell website ....install it ....restart your system ....it will work fine...
good luck :-)
Apr 26, 2010 | Dell Precision M60 Notebook
How to remove the cmos battery on a dell precision m60
Here is the link to removing the reserve battery. http://support.dell.com/support/edocs/systems/wsM60/SM_En/reserve.htm#1123661
However, if you are trying to bypass a BIOS or HDD password removing the battery will have no effect. Those can only be removed by tech support or a hardware replacement.
Dec 05, 2009 | Dell Precision M60 Notebook
Laptop New LCD Screen Cycling Colors
It's probably the wrong screen, cable ,or inverter; in spite of what the repair shop tells you .
Also, sometimes the cable gets pinched if not installed carefully, or the cable connector may need to be re-seated.
Is your laptop a Dell Precision M60 ? I'll see which screen it's supposed to have.
Jul 28, 2009 | Dell Precision M60 Notebook
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
Laptop video failure
Sounds like you may have "hit the problem" But to me sounds like the chip itself is no good anymore. Any chance of getting a chip off another board and replacing it?
Jan 27, 2009 | Computers & Internet
Dell Precision M60 Notebook Logo
829 people viewed this question
Alun Cox
