Question about Dell 922 All-In-One InkJet Printer
Motor whirrs but I can't print
I pulled paper from the printer because it was taking 3 or 4 sheets instead of 1. Now when I switch it on, the motor whirrs and the computer still says 'Paper Jam'. I tried to switch it off and on but no good.Can anyone help me fix this? I can't afford a new printer and I really need to print. HELP!
  • blitz04 Oct 19, 2008
    mine does the same thing it keeps on saying paper jam, but there is no paper in the damn thing
    Scholar:
  • 155 Answers
Either the gears of the paper feeder are cracked or misallignewd and needs to be replaced or readjusted or the sensor which detects the paper in the tray is broken. so you r facing this error. please check it out. it will solve your problem. this is a common problem faced by many users and get proper . if you dont have any idea of how to check it out.then call a technician he will do it for u.the cost will be negligible.
thanks.
Posted on Oct 26, 2008
Keeps saying paper jam and paper goes half way through
hi
1. 1 Switch off the printer and disconnect the powersupply. Allow any residual charge to fade away before putting your hands ormetal tools inside the chassis. 2. Step 2 Pin down the exact location of the jam. Thethree hot spots for a jam are the paper tray, anywhere between the feed trayand the print carriage, or between the print carriage and the output tray. 3. Step 3 Take off the front paper tray if the sheet gotstuck while it was still in the front area of the printer. If the sheet jammedhere, you should be able to see most of the paper. 4. Step 4 Pull on the sheet with both hands and steadypressure. Do not tug as you might rip the paper, leaving a chunk of it deeperin the machine. 5. Step 5 Open the back panel to reach paper jammedbetween the feed tray area and the print carriage of the all-in-one printer.Carefully remove the jammed paper from the machine. 6. Step 6 Use the carriage access door to reach a jamfurther inside the all-in-one printer. You may need to move the print carriageout of your way to clear the jam. 7. Step 7 Return any access panels to their closed andlocked positions. Plug your printer back in and flip the power switch.
Oct 31, 2010 | HP PSC 2355v All-In-One InkJet Printer
HOW TO REMOVE BLOCK PAPER
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Oct 26, 2010 | HP LaserJet 1320 Printer
WILL NOT PICK PAPER SAYS PAPER JAM
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
Aug 17, 2010 | Dell 924 All-in-One InkJet Printer
Keeps asking for paper and will not print
hi
vote me if you find your solution
Aug 11, 2010 | Canon PIXMA MX310 All-In-One Printer
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it...
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jul 07, 2010 | HP Deskjet D4160 InkJet Photo Printer
It wont print
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 22, 2010 | Brother HL-2040 Laser Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Printer
2.
3.
4.
5.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 03, 2008 | Office Equipment & Supplies
Dell 922 All-In-One InkJet Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
