Question about HP Photosmart D5160 InkJet Printer
Printer not responding1
My photosmart printer is not responding when i press the print button? i don't have disk.
    Problem Solver:
  • 18 Answers
First check the usb cable of the printer and try to use other cable. if did not work try to download and re-install the driver of the printer.
Posted on Oct 04, 2008
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
The error message is Oxc18a0001. What is wrong with it. I've turned the printer off like it said to do, with no change.
Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
May 06, 2011 | HP Photosmart D7460 Printer
How do I do a nozzle check for hp photosmart premium?
You need to print a print quality report to do a nozzle check.
Press SETUP
Press the down arrow button to highlight TOOLS
Press OK
Press the down arrow button to highlight PRINT QUALITY REPORT
Press OK
Feb 05, 2011 | HP Photosmart Premium C309A All-In-One...
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
How can I get the mac address for my printer ( HP PhotoSmart C4385 )
Look through the menus on the device for printing a "Network Configuration Page"
Look for "Hardware Address" on the page that prints out.
Hope this helps you!
Leave a rating if so!
Mar 04, 2010 | HP PhotoSmart C4385 All-in-One Printer
HP C6180 responds to print but puts out blank pages
All I had to do was clean the print head. Try these steps: Press setup, scroll down to tools. Select clean printer head. The printer will run a clean cycle and then print out a diagnostic test page.
Jun 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
Photosmart printer not printing
Hey Hi!i!ii!i!i!i,
Firstly Insert The Printer's Driver Software Disk In The Computer And Completely Uninstall The Printer Driver Software. Don't Remove It From Control Panel.
You MayUse Any Uninstaller Software For Removing the Printer's Driver SoftwareAnd If You Don't Have The Printer's Driver Software Disk.Here's The LinkFor Uninstaller Software. ( It Will Work Only With WINDOWS OPERATINGSYSTEM)
UNINSTALLER SOFTWARE
Then Clear The Temp And Prefetch Files.
Disconnect the printer's cable form the back of the computer and disconnect printer's power cable and turn it off.
Press and hold the printer's power button for 30 Seconds then release it.
Turn off your computer and then disconnect all the cables from the back of the computer.
Press and hold the computer's power button for 30 Seconds then release it.
Wait 2 minutes.
Hook up monitor, mouse, keyboard, internet connection and power cable and then restart your computer.
Hook up printer's power cable and then turn it on.
Hook up printer to the computer.
Click on the link below and download and install the LATEST PRINTER'S DRIVER SOFTWARE AND FIRMWARE AVAILABLE, IF ANY..
WINDOWS XP DRIVERS
WINDOWS VISTA DRIVERS
FOR ANY OTHER OPERATING SYSTEM ----->KINDLY CHOOSE THE OPERATING SYSTEM.
Restart Your System.
Issue Resolved.
Feel Free If u need any further help.....Kindly Rate Solution..
May 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Photosmart C3150 printer
Press the control panel. Select printers. Move the icon to the printer. Press the right mouse button by selecting properties.
Press the printing preferences button. Select the services tab. Press the service this device button. Press the align print cartridges button.
Jul 13, 2008 | HP Photosmart C3150 Printer
HP Photosmart D5160 InkJet Printer Logo
57 people viewed this question
Ben Johnson
