Question about Garmin eTrex GPS Receiver
Entering coordinates into a etrex yellow
Can any one in simple terms tell me how to manualy enter coordinates into an etrex yellow model
say coordinates from a google earth map
Thanks brian green
  • Garmin Master
  • 638 Answers
Mark a waypoint, then edit the waypoint, entering the new co-ordinates.
Posted on Oct 09, 2008
How to put in coordinates
Coordinates can be entered by marking the waypoint and editing it.
From the map screen, press the joystick down for 2 seconds to mark the waypoint. Toggle up to the coordinates and press the joystick to enter the edit mode. Make the changes to the coordinates to the new coordinates and toggle to OK, press the joystick to enter the coordinates.
Dec 10, 2011 | Garmin eTrex Venture Cx 2.1 in. Handheld...
How do i enter gps coordinates into my garmin etrex hc
Hi Jdriscoll38,
Since you probably have been using this device, you know it will automatically receive and lock in on the coordinates from at least three satellites if you move outside to a large cleared area, and power up. I could list all the steps to manually set all the coordinates, and that would take a couple of pages. Download the entire 56-page manual at this site, and refer to the pages below:
http://www8.garmin.com/manuals/eTrex_OwnersManual.pdf
Go to the top of page 20 to change the Position Coordinates.
Right below those instructions, you'll see the info for changing the Elevation.
In case you don't have this manual, after download this, you should have all the instructions you need for all operations.
Let me know if I can help further. Thanks.
Regards, Bill
Sep 18, 2010 | Garmin eTrex GPS Receiver
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
The coordinates that I get are 30 metres off from the other GPS units that we geocache with. My settings must be off.
Yes, have you enabled WAAS on your 60CSx? WAAS is an acronym for Wide Area Augmentation System, according to the instruction manual an FAA funded service to improve overall integrity of the GPS signal through North America.
If you are in an area which is not serviced by ground stations, having WAAS enabled may degrade the signal from the GPS satellites. Try enabling or disabling this feature.
To do so, acess the System Startup Page. On the Setup Menu page, highlight the System icon and press Enter. WAAS is the second available setting on this page.
Make sure your batteries are fresh; I prefer alkalines in this model. Set the battery type in the System Setup Page, same page as noted for WAAS above.
Another thought is to be sure you have the latest Garmin software installed. Visit their site to download the latest and greatest, free, of course.
May 20, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Cant find how to manually input cordinates
First create a waypoint, and then modify it. Hold down the enter button for two seconds (the thumb-toggle on the face of the unit). This opens a screen with a number at the top and coordinates of your current location below. Once you've grabbed the coordinates you can change the name and the coordinates and the name and save it as a waypoint. Use the thumb-toggle to bring up number pads and letter pads for each line.
May 07, 2009 | Garmin eTrex Venture HC GPS Receiver
How do I convert the gps coordinates from Google Earth?
In GoogleEarth, change your coordinates to decimal format. In your Lowrance GPS, change that format to decimal. You don't mention which Lowrance model so I can't find the online manual to tell you exactly how to do it.
Jan 01, 2009 | Garmin eTrex Legend GPS Receiver
How do I enter gps coordinates into my Etrex H
Mark a waypoint, and then edit the waypoint's co-ordinates. You can also create a waypoint in Mapsource and then transfer the waypoint(s).
Jun 29, 2008 | Garmin eTrex GPS Receiver
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
Loading gps marks e Trex hand held yellow
Your manual tells you how to enter waypoints
http://www.fixya.com/support/p237226-garmin_etrex_gps_receiver/manual-14514/page-16
Mar 29, 2008 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
2,211 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
