Question about GE DSKP233EWWH Electric Portable Dryer
Dryer timer was working
Yesterday and now it stop working it manual shut down when the door open why ?
  • 2 more comments
  • faceoff1 Oct 04, 2008
    so how do i fix this now to amke this work ok?i did open and shut cause i wanted make sure it was turnning the tub ok ?
    so how to fix it
    tis manual shut it self down is cause i open the door ok but how does one fix the timer shut it self down
    so just let it cool down then for a while anwer this and i wil rate you ok
Ok so how i fix it now it click when pusp it manual ok why wouls it stop working ok ?
Posted on Oct 04, 2008
  • 958 Answers
Because there is a door switch that would turn your dryer off because of safety issue.
tnx 4 using fixya,
drcool
  • francis rivero Oct 04, 2008
    if you do not open the door, the timer will continue to run and it will shut down automatically.
    you can not by pass the safety switch. you can not look at the drum if it is turning, it is unsafe to open the door while the drum is turning.
    tnx 4 using fixya,
    please rate my solution. was it fix?
    drcool
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Dryer stopped working, sounds like timer still running
I suspect it is the thermal fuse. Seen here. You will need to determine what caused it to blow. on these machines the blower wheel is notorious for getting loose and causing the element to over heat. This makes the heating element shut down faster and takes a long time to dry the clothes. 7fc125e.jpg
Apr 10, 2010 | Magic Chef CYE4000AWW Electric Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Dryer switch
yeah but its unsafe specially with kids! it could stay running if the door was open and wont stop unless you turn the knob or unplug it. thats if it was bypassed.
Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
My Kenmore drier won't stop now! Perhaps timer isn't working?
Hi there. this is a timer issue. it counts down but, the actual shut off dial embedded in the timer mechanism is damaged for some reason. replacing the timer assembly will correct this issue. there are two parts to a timer. One, it times and last, it initiates the shutoff. the second action is not working properly. to be sure, check the relay before you purchase the new timer.
I have also provided you with a complete manual set that you can access and print out if you would like.
Click here for your manual
Click here for your instructions Guide.
Mar 06, 2009 | Kenmore 84052 Dryer
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
GE DSKP233EWWH Electric Portable Dryer Logo
53 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
