Question about Toshiba 26WL46 26 in. LCD Television
Audio Hi I connected headphones to the appropriate outlet on the TV,on removing the headphones the tip of the jack became detached and remains in the outlet so that no audio is available from the inbuilt speakers. Any advice on removal would be appreciated?
    Sergeant:
    Champion:
  • 223 Answers
If you are electrically minded I cant think of another solution apart from to open the set and de-solder the socket from the board and then you might be able to gain better access to the stuck pin. Some of the sockets are open at the back enabling you to poke something through the gap so you might be one of the lucky ones. Please remember to take all necessary precautions while working on the tv especially the discharging of capacitors as a spark from one of those could do a lot of damage to the tv or yourself. If you open up the set and it looks too complicated please dont feel like you have failed just put it back together and find a competant technician. Good luck.
Posted on Oct 04, 2008
WILL IT WORK ON A TV THATS NOT BLUETOOTH CAPABLE
Hi Mike,
The TV requires an audio output jack. Either an Optical, a stereo "RCA phono" type or a stereo 3.5mm "headphone" type jack with the appropriate cable to mate with the speaker's optical or RCA input jacks are needed.
Download the manual from the page linked below under "Manuals and Downloads" and read page 7 where the details of these connection can be seen.
Pyle PSBV600BT Home and Office SoundBars Home Theater Sound and Recording...
Jul 14, 2015 | Pyle PSBV600BT Sound Base Bluetooth...
Just bought a Samsung smart tv and a pair of brookstone wireless tv headphones, however after setting the transmitter I am unable to get any sound on the headphones. I do not have a cable box or gaming...
try your headphones on another device to ensure the headphones are not the problem. ensure any mute or volume switch on the headphones are turned up. and ensure the batteries in the headphone are charged. check attn try both 0 and -8db setting,
check both headphone outlet and tv speaker outlet of smart tv. in TV settings ensure the audio out setting is set to ON so that the jacks for audio to external speaker are switched on.
i hope this was useful.
Dec 26, 2014 | Audio Players & Recorders
How do I connect a wireless head set to a Dynex Television Model DX-37L200A12
Using the appropriate cable for the transmitter that came with the wireless headphones, connect one end of the cable to the AUDIO OUT jack on your TV set and the other end to the AUDIO IN jack of the transmitter. If your headphones came with rechargeable batteries, don't forget to charge them before using the headphones.
H
Dec 08, 2014 | Dynex Computers & Internet
How to hook up my toshiba c655 to tv and have audio
If you have HDMI out on your laptop, it should send the sound and picture to your TV (make sure appropriate drivers are installed).
If you only have VGA out, then it will not send sound. Tthe only other option is if your TV has Audio IN (either 3.5mm headphone jack, or RCA Left/Right), then you could connect the headphone jack of your laptop to the TV that way.
Jun 19, 2012 | Toshiba Satellite C655-S5082 Laptop
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
How do i connect my headphones? when i use a red/white tulip - jack out cable and then connect the headphones jackplug there is no sound, using the 'variable sound out'. should i use an amplifier like a...
If your TV does not have headphone jack outlet, then there is not much you can do, the Audio line level out RED and WHTIE RCA jaks are not made to drive headphone directly, it does not have enough power to drive low impedance load such as headphone which has about 8~32 Ohms impedance, the line out RCA is made to drive high impedance load 20,000 Ohms and higher.
If you want to use headphone, what you can do is to get cheap powered PC speaker system that has headphone out jack, then just connect the powered PC speaker to the audio line out of the TV, but the TV must have an option on the audio setup to turn off the built-in speakers.
http://s807.photobucket.com/home/budm/allalbums
Jun 12, 2010 | LG 26LC2R 26 in. HD-Ready LCD Television
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Apr 23, 2010 | Beyerdynamic DT 100 Professional...
THERE IS NO HEADPHONE OUTLET JACK PLUG ON MY ELCD40USBFHDLCD TV.HOW DO I USE HEADPHONES?
No jack - no headphones.
Unless you run the audio to some "box" that has jack for you to use.
Jan 13, 2010 | Naxa Electronics NX-545 20 in. LCD TV
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Toshiba 26WL46 26 in. LCD Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
