Question about Logitech Inc MM50 Portable Speakers iPod Computer Speakers
Helpme! Battery Death!
I don't open my mm50 for a 6 month. Since I use this speaker again. My Battery is Gone!. I Can't Charged it's Power. But I Can Open a Speaker when I Connect the speaker with a plug. But when Chaged battery is not
increase. When I Open Speker with un-pluged Charged. It have a 3 red blinks and cannot open. But when use pluged charged It can Open.
I try to Charge at all costs. charge when playing. charge when turn off.
charge when I sleep. But the Problem is not Gone.
Can you Help me , Every One
Ps.I want how to repair or change battery
I don't want to buy another one and I Live-
in Thailand. don't tell me to repair in an other-
country. because I have low money.
    Top Expert:
  • Logitech Master
  • 12,962 Answers
You cannot repair or bring back to life a dead battery. Get some money and buy a new one.
Can you bring back to life a dead human?
Posted on Mar 22, 2017
SOURCE: One Speaker Stopped Working
Check d audio configuration:d balance point especially(it should b right n d middle)
Reinstall d audio driver if d above does not work.
Have u tested d speakers on another device?
Although d cable seems to fine,there can b internal cuts n d wire.
Please feedback if d above dsn't help
Posted on Jun 01, 2008
SOURCE: Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Check out the troubleshooting tips on the PDF file at  http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=t2HdY9Si&p_li=&p_accessibility=0&p_redirect=&p_file_id=44208&p_tbl=9&p_id=5190&p_created=1155250699&p_olh=0
(sorry for the long link). Flashing red indicates data loss.
Posted on Aug 07, 2008
SOURCE: Logitech X-240 Speaker Volume Problem!?!?
you probably have it plugged into the wrong jack
Posted on Aug 16, 2008
SOURCE: logitech z560 set up help
The 4 satilite speakers are all the same. You can get new speaker wire at the local Radio Shck or electronics store. They just recomend an 18 gauge wire. When you wire them the red terminal on the speaker is hooked to the red terminal of the sub woofer speaker. On the back of you volume controller there is a place to plug in the wires from your sound card or motherboard. One cable will do the front speakers and another one will do the rear speakers.
Hope this helps.
Posted on Aug 31, 2008
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
Starting
The battery is undoubtubly defective.
Apr 17, 2014 | Holden Astra Cars & Trucks
Jazz tablet won't open and heats up
Its sounds as if your battery has gone open circuit which means if is now dead and requires to be replaced. Dont continue trying to charge it as you may cause damage to your tablet or cause it to overheat and start a fire.
Nov 29, 2017 | Jazz Tablets & eReaders
Car not statrting
The battery could be ***** could have voltage but not crank power.
May 10, 2017 | Cars & Trucks
The battery led blinking red/green
Disconnect power cord. Please take out the battery. Hold down power button for a minute and then connect only power cord. Restart it again.
Jun 24, 2013 | ASUS Computers & Internet
I perchased my rca mp3 player last month and loaded my music onto the device and now it wont turn on ,I just took it out of the package and charged it per the instructions and loaded my songs onto it but...
remove the battery from the unit then press and hold the power on button for atleast 1 minute this should reset the system then return the battery then charge the battery for atleast 2 hours just to ensure your battery is full charge..the turn the power again.The player should be ok now..
Aug 29, 2011 | Car Audio & Video
It wont charge at all. I haven't used it for years and when I placed the headset in its case & plugged the case in to charge...it doesn't seem to pick up a charge at all. I hold down the power button...
Your phones battery is faulty,the connections inside has gone open circuit and the cells are completely damaged.It will never take a charge again and the only solution is to replace the battery.
Rechargeable batteries go faulty if they are not used or charged for 6 months plus.
Mar 17, 2011 | Cell Phones
Reinstalled audio gone when I RESTARTED
sounds like your cmos battery is bad does the time and date need to be fixed each time it is powered off after battery power or when you install driver you are tellingit ok and restarting it?
Oct 19, 2008 | ASUS Eee 4G Notebook
Blinking Green Light of Death
I had this similar problem TWICE!!!. I called around for a repairman and they charged over $300 dollars to repair (HELL NO). Anyways I took a trip to Vegas hoping to win some of the money to repair it and left the TV plugged in and BLINKING during my trip. When I came back it was not blinking anymore and I got curious. Well I pressed the power button and to my surprise IT TURNED ON!!!!. A month later I moved to a different house and unplugged my TV to move it and when I plugged it in the DAMN BLINKING GREEN LIGHT OF DEATH was back. Well I thought I'd get lucky again and leave the blinking on, well 2 days later the blinking was gone and ONCE AGAIN MY TV WAS ON...... I hope this helps and works for other people. My point is, before you pay for a technician to repair it and before you give up on your TV and unplug it, Try leaving it on BLINKING for a few days and see what happens.
GOOD LUCK GUYS.
Oct 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Will not charge
If this Problem has come because you not use a speaker for a long time.I Know How to Repair. In This Morning. I had a Problem Like you but I Can Repair it. Try it you Self.I use a Plug and Play a lot of time. lot of charged. and a lot of on-off switch mm50. I do this for a 12 hour. in my school holiday. Battery is become life! . I Can Portable with It Again. but now is mid night
PS.This is true , I test with myself to Resurrection that Death Battery
Oct 03, 2008 | Logitech Inc MM50 Portable Speakers iPod...
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
