Question about Conair HC100RCS Hair Trimmer
I want to disassemble my trimmer but i dont know how
How can i disassemble my canair HC111Dcs i think its much the same with HC111RCS i cant see any screw upon it how can i dis assemble it? i want to rewind the coil bacause i pluged it to 220v and its only 110V. please help me..
how can i disassemble my canair HC111Dcs i think its much the same with HC111RCS i cant see any screw upon it how can i dis assemble it? i want to rewind the coil bacause i pluged it to 220v and its only 110V. please help me.
  • Conair Master
  • 1,830 Answers
Do you have an owner's manual for this trimmer?
Posted on Jun 18, 2017
2 Suggested Answers
  • 6 Answers
SOURCE: plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Posted on Mar 09, 2009
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
How to disassemble Philips QG3080 Beard Trimmer
dimitris, use brush to clean hair and don't open the machine.
Nov 09, 2013 | Philips QG3080 Beard Trimmer
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
I pull cord it turns over but to no avail, it sounds like it wants to start. I think it has to do with the two small screws underneath the throttle dont really know the names i checked the spark plug...
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carburetor cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 13, 2010 | Craftsman 25cc Gas Line Trimmer
When I clean the inside of my clippers a metal o-ring fell out and I dont know where to put it. I dont have a clue where it goes
This may be the hanger to the trimmer, if this the part I think you are writing about it place at the electrical cord between the cord and the trimmer housing
Mar 30, 2010 | Andis Edjer 15515 Beard Trimmer
My homelite trimmer model ut20006 will not run unless it,s on half choke. I think it,s the low speed jet but where is it and how do I get to it thanks
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Trimmer wont run when i take it off choke
No, it will not. Don't take the fuel mix screws out, it's not necessary.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
Jim
Jun 15, 2009 | Craftsman 25cc Gas Line Trimmer
Conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Conair HC100RCS Hair Trimmer Logo
1,611 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
