Question about Memorex MVD2042 DVD Player
How to hook up a dvd player to a dtv
Dvd player hooking up
  • Caseyslair Mar 29, 2009
    The comcast box has a RFin, and the old VCR/DVD was hooked up through it. So what is different???
Ok don't laugh but I found a Zenith DVD player I had bought several years ago, and had not used. I am now trying to hook it up, and cannot. I currently have Comcast, with a DVR box, and I have tried everything. I can get sound but know picture. Help!
Thank you,
Karen
Posted on Mar 29, 2009
    The Comcast DVR Tuner, has a RFin, but that is all I see. The old DVR/VCR was hooked up through the cable box so I am not sure why this one won't.
    Scholar:
  • 124 Answers
Hi, If the DTV does not have Video IN, then you can't. Thanks, Mike
Posted on Nov 03, 2008
JUST GOT THIS HOOKED UP THIS MORNING,NICE TV.ANYWAY NEED TO HOOK UP MY DVD PLAYER NO VIDEO BUTTON TO CHANCE FROM TV TO DVD WHATS UP? MOVIES WILL NOT PLAY
input source button and what input did you stick the DVD player into was it HDMI1 port cause if it was you would change input source to HDMI1 from DTV input source.
on the tv you have the remote control it has a source button just left of the channel up and down + ch - buttons.
Nov 15, 2015 | Seiki 39" Class 1080p 60Hz LED HDTV...
Zenith KBV713 DVD/ VCR combo
hmmm...do you have the user manual on the DirectTV unit?
May 31, 2008 | Zenith XBV442 DVD Player/VCR
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
How do I hook up dvd player
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
Jul 31, 2009 | Sansui DTV3200 32" TV
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I cannot get my phillips dvd/vhs hooked up, i have direct tv can you help me? thanks Joe
Ok the DTV box must have connections that first run to the dvd /vhs ( out of outputs on DTV box into the inputs on the dvd/cd player then from the player out to the TV RED/WHITE/YELLOW inputs! make sure your tv and unit are on channel 3
This should fix ya right up! If you need more help come back and see us!
(Please use the ratimgs system! This keeps this site free)
Dec 14, 2008 | Televison & Video
Have a problem
Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
Antenna ---- converter box ---- Switch box
XBOX ---------------------------------switch box
DVD -----------------------------------switch box
And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Memorex MVD2042 DVD Player Logo
130 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
