My oil boiler is a Danesmoor SLPJ 20-25 with an Electro Oil Inter 2011 burner. The oil tank ran out and after refilling the burner ran ok for approximately 6 minutes, the control box chattered and the boiler sound indicated flame out, with the blower continuing then re ignition, flame out, re ignition, flame out and then lockout. Considering restriction / air lock in fuel line, the tank filter was changed, pump filter was cleaned and fire valve was cleaned out which was giving a gunge restriction. Fuel flowed freely into a bucket at connection to burner. The problem is still exactly the same with an approximately 6 minute run, flame out, re ignition, flame out to lockout. Any ideas, Keith
  • Anonymous Mar 14, 2014
    Hv a Bentone 832.3 boiler. Ran outv oil last sun, refilled tank nw the pump won't stay on! Help plez
The actual final solution was to replace the fuel valve/solenoid following which the boiler has run without failure.
The conclusion was that the fuel valve solenoid was ok when cold but when heated up had some sort of electrical breakdown in its coils, causing the fuel valve to fluctuate until the boiler locked out.
Posted on Oct 17, 2008
  • 958 Answers
You could have a problem with a temperature sensor.
it would not be the flame sensor since it could not wait 6 mins to sense that there is flame in the unit.
could be a temperature sensor problem where it is sensing a temperature which could be correct but it is sending a wrong signal to the controller to turn off the flame and start another cycle.
tnx 4 using fixya,
drcool
Posted on Oct 04, 2008
Ran out of oil, when refilled managed to get heating working but oven not
How to bleed and restart your oil heating. - Instructables
www.instructables.com/.../How-to-bleed-and-restart-your-oil...
InstructablesGo to the oil tank and make sure there's oil in it, or you'll be wasting your time. ... you to get lucky but it has happened to me and it seems to help get the fuel moving a ... I am thinking the boiler is not working so do not want to spend money buying lots of ... Bleeding brilliant - now the wife doesn't have to know we ran out of oil!Missing: oven
how to mend it .com - Clearing airlock from riello oil burner?
www.howtomendit.com > Heating, Oil Filled Radiators
The temp knob on my bosch oven has stopped working. ? Search: Go ... I've now replensihed the oil but the system keeps cutting out after a few moments trying to ignite the oil. ... With guests arriving to rent my house yesterday, I ran out if fuel,refilled and ... Have now managed to restore heating and hot water to my house.
My Craftsman lawn mower wont start after it ran out of gas ...
www.shopyourway.com > Manage My Life > Questions
Dec 21, 2015 | Ovens
Danesmoor slpj20-25
Hi try this link and go to page 16 fault finding it should give you a clue, I think it may just need bleeding. http://www.bhspares.co.uk/wp-content/themes/RevampV3/manuals/Worcester%20Bosch/DanesmoorSLPJ15-19.pdf Cheers Andy
Dec 30, 2013 | Heating & Cooling
The oil tank ran dry..now the boiler wont light now the oil tank is full
Here is a tip I wrote about how you can bleed the air out of the lines to get the oil burner working again...
How to Bleed Oil Burner - Beckett Oil Burner Repair
heatman101
Jan 05, 2011 | Heating & Cooling
Ran out of oil, now refilled, but boiler won't ignite. Tried all as owners manual instructs, but still keeps locking out - help please
After running out of fuel,you need to bleed the oil pump on your burner.There should be a 3/8 bleed port on the bottom of your burner pump. The bleeder valve looks like a nipple. A 3/8 opened end will fit over it.Put a can or cup under it,open it a bit and reset your control.when pure oil comes out close it and burner will fire.If your not good with it you should get a tech or handy man to do it.
Nov 27, 2010 | Heating & Cooling
Oil boiler reset button not working. ran out of kerosene the other day got a refill but after pressing reset button ... nothing. i know about bleeding the oil ine done it before but seems to be getting oil...
Your Nozzle is probably plugged. I've found that to be the case most times. I work for a oil company and have found when people run out it tends to pull crudd from the bottom of the tank and plugs the nozzle. and while you're at it, you should change the oil filter and pump strainer. Good luck. If your unsure how to do any of the repairs I highly suggest you call a service guy to do it for you. Oil burners can be very dangerous, and can be a supplier of carbon monoxide in your home. Be carefull.
May 01, 2010 | 1999 Pontiac Grand Am GT
Vulcan oil heater won't restart
if it is a two line system the pump should prime its self on a one line system there is a bleeder screw 3/8" on the pump but remember every time the reset is reset the pump could be adding fuel to the burner so make sure it is getting spark you should here it hope this helps also make sure you have fule not water in lines
Jun 08, 2009 | Heating & Cooling
I need to restart my boiler after running out of oil
Try a website called www.repairclinic.com and see if that will answer your problem.
Jan 19, 2009 | Water Heaters
Fuel oil level extremely low: possible problems?
After your fuel tank is refilled let it set if possible for solids to settle. In the line near the tank is a fuel filter. This fuel filter should be changed regularly, normally annually. The air must be vented from the fuel filter though vent screws located on top of fuel filter. Do not remove the screws completely as air will vent as they are loosened. At the burner oil pump is a vent to which you can slip on a 1/4 inch hose and direct into a container. On burner start up loosen the vent at the oil pump and observe oil going into container. When solid stream of oil is seen close the vent. The vent looks like a grease fitting on an auto.
follow these instructions: One problem that can occur is the nozzle for the burner sometimes becomes plugged if solid particles make their way to it under low oil conditions. If this becomes the case you should have a heating service tech change the nozzle and fuel filter. However try the venting procedure first. You just may be O.K.
Dec 15, 2008 | Heating & Cooling
Oil boiler won't run
What make and model burner do you have?
Feb 23, 2008 | SySTOR Systems (400S52) Burner
Heating & Cooling Logo
354 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
