Question about Compaq Presario R3000 Notebook
Wireless problem Just did a restore with factory frestore discs. Before restore had no probllems connecting to the wireless in home....now can not do....What would I look for as a wireless card? I am thinking a driver is missing or that at one time someone put a different one in...I am really at a loss.I did use another usb connector that have in house to go update windows,etc etc...since restore discs have outdated things?
  • girlfrommars Oct 08, 2008
    Hadden't used wireless before but have restored and cannot connect.
    Genius:
  • 1,124 Answers
Reinstall your wireless drivers card again
Posted on Oct 13, 2008
Wireless n
Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router. the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops-computers needs to be configured with these router's wireless settings. Then the laptops-desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop-computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
May 16, 2013 | Cisco - Linksys Wireless-n Home Router -...
I just used recovery disk to restore back to factory setting for acer aspire 7741Z. Now it won't recognize my wireless router
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 28, 2012 | Acer Aspire 7741z
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
HI,
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
My girlfriend put in the pin number of my wireless into her PC and it renamed my wireless network and I can not longer secure my wireless network. I have a Mac and I do not know how to reconfigure it to...
On her PC, connect again to your router.
Click Start
Click Run
Type CMD
Press ENTER
Type IPCONFIG
Press ENTER
Look for output like: Default Gateway ... 192.168.123.456
(Your numbers may vary!)
Start Internet Explorer
Type http://192.168.123.456
Login to the CISCO router's web-interface.
Click "Restore Factory Defaults".
The router will restart itself, and you will need to reconfigure it.
Jul 30, 2011 | Cisco - Linksys Wireless-n Home Router -...
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
Wireless internet is not working after restoring factory settings
Oh, wireless Internet? You restored it? Did you install a different operating system? Or had you installed one before resetting? A change of OS may result in the deletion of particular drivers.
Go to the manufacturer's website. There, search for your model's support and download the drivers you want, for instance, the wireless network adapter drivers. Also, check your sound.
Jan 30, 2009 | IBM ThinkPad R40 2722 Notebook
Reloaded Windows Vista
you can try the ff:
► double check the wireless if it's enable or disable. click start > start search > windows mobility center > turn the wireless network ON.
1) reinstall the wireless driver of the computer using the driver disc or using the recovery partition....
2) tried to set-up the home wireless conenction in "Home Set-up Wireless Network" and follow the instruction.
3) reseat wireless card if it's reseatable.
4) download the BIOS update using ethernet cable from the pc website support.
3) contact Internet Service Provider.
4) reinstall the windows to the factory condition.
Sep 19, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Unable to get Wireless to turn on
Sandy,
What was the earlier problem?
Do you think it is/was/might be related?
How did you get past the issue? If you formated, you have to go through "Software Setup" find it at Start, All Programs, Software Setup. (tc1000) or if you restored with the factory discs (tc1100) then it should be done. If a tech "restored" your tablet with other than the factory restore discs, then Q menu may be impaired or nonfunctional.
Is the card actually there?
Are the cables connected?
Is the card the original hp card? Some others will not work with the Q Menu.
Go to hp.com, navigate to the tc1100 support page and download all drivers or recent updated drivers.
Install the updates and you should be fixed.
HP will sell you restore discs for $10.72 (thats what I paid last fall) that will install the correct drivers for the unit. Cheap at twice the price. You will need a keyboard (USB generic will work if you don't have the original detachable) and an optical drive (USB CD Drive) basically to do this.
My friendly local tech is at $50 for basic service, and if you can back up to another PC (cat 5 cable connection is fastest) or a card, then a reformat never hurts a thing, kills many troubles too!
Best Luck, Blaino
Apr 23, 2008 | Compaq tc1100 Tablet PC
Compaq Presario R3000 Notebook Logo
140 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
