Question about Lenovo ThinkPad T61 Notebook
Processor noise on T61
I got a thinkpad T61 and after 3 months usage i get unusually loud processor noises like the system is overloaded. and its really annoying. i do use it a lot but would appreciate if someone could tell me if this is normal or not?
  • Anonymous Oct 16, 2008
    I have a T61 that makes a sharp buzzing (almost like interference) noise that comes out of back left side of the computer anytime the computer is not hooked up to a power source.
You need a clean up on the cooling system. Go to youtube and see the video on how you can do it yourself. Search for T61 thinkpad.
Posted on Nov 07, 2011
    President:
  • 2,022 Answers
It is happen when laptop become hot,there is sensor which tell fan to run faster if system is hot.try to get ur laptop in cool place and see.
Posted on Oct 21, 2008
Will dried thermal paste make the fan run loud on a dell 4700?... when i power on, fan makes loud noise, black screen and wont boot and the power light led is amber (no blinking).. i changed the fan, tried...
You may try to remove the fan, clean it up. Also try to remove the processor heat sink (clean the thermal paste), reseat the processor, put a little thermal paste, that assemble it back. Before you do this, ground your self first(the easier way, hold any metal).
If this can't help,check the capacitor at your MoBo and if you found any unusual look like, it mean you need a new MoBo.
Jun 08, 2012 | Computers & Internet
I am planning to buy T60 thinkpad, CPU is 1.6 GHz, Cheaply available in the the market. Also I have the processor of a T61 thinkpad which is 2.4GHz. I can put the T61 processor into T60, do you have any...
I don't believe it will because the heat sink and CPU screws won't line up and the CPU is smaller but i'm not for sure.The board architecture is the same but the form factor i believe is different.I'm sorry but i can't say for sure and i don't want to lead you to a bad conclusion.
Nov 07, 2011 | Lenovo ThinkPad T61 Notebook
I am getting sound in my system
HI User ,
The sound from system can come due to various reasons, The most common reason is the CPU fan which located in the back of the CPU tower and also just above the CPU Processor . Due to Heat Sink between Processor and Fan ,it can create a loud noise when the CPU usage is high , I would recommend you to change the fan and check if that fails ,you have to checkn the heat sink issue in the processor Fan .
Thanks and regards
Aboobackers
Internet explorer Expert
Nov 28, 2010 | Computers & Internet
OK I think my laptop makes noise because of the fan.
Thanks for using FixYa.
It is normal for the laptop's fan to make noise. Sometimes, the noise will not be as bad. The noise actually depends on how hot your laptop is. The hotter the laptop becomes, the louder the fan noise. Your laptop will produce heat depending on the load of the laptop's processor. So if you are multitasking on your laptop, expect the fan to spin faster because it will try to eliminate the extra heat being generated.
I just have a quick tip for you, never use your laptop on top of a bed or any soft surface because the vents under the laptop will not work properly.
I hope this helps. Thanks and good day.
HotRatchet
Jun 20, 2010 | Lenovo ThinkPad T61 Notebook
Makes loud vibration noise (not there when
brewer needs to be descaled use and care guide recomend it to be done every 3 months. Do it religiously according to that time frame regardless of how filtered your water is
Mar 16, 2010 | Keurig B60 Coffee Maker
The outdoor fan on my central a/c is suddenly making a lot of noise. I have a Bryant - model #697CNO36. Thanks
Depending on the age and usage of the motor. And whether or not the motor is an oil-free motor or not will help to determine the problem.
Most times, a loud noise coming from a motor itself is contributed to the bearings going bad in the motor. This can be cause by lack of maintenance, blades out of balance, or the blade too far down the shaft and creating unusual wear on the motor.
You will most likely need to replace the motor and run capacitor in order to get rid of the noise. But only finding out how and why the noise started will allow you to prevent it from happening again.
Jan 12, 2010 | Bryant 463AAC008BA Air Conditioner
Thinkpad T61 went dark abruptly after startup
Make system restore, or better reinstal vista from IBM image file, dont install any updates, go get windows 7 , and get rid out of vista.
Oct 31, 2009 | Lenovo ThinkPad T61 Notebook
Fridge makes howling noise
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
Jun 21, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Lenovo ThinkPad T61 Notebook Logo
439 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
