Question about Kenmore 67082 Electric Dryer
Dryer is displaying AF
The dryer is displaying a blinking AF. Any idea what this is?
  • 958 Answers
I got this from the other site.
The code AF indicates that the control senses a restricted air flow. To clear the code, press STOP once and the estimated time remaining countdown will return to the display. The AF code will continue to appear with each cycle until the low airflow condition is resolved.
Try the following troubleshooting to resolve the air flow problem:
  • Clean the lint screen.
  • Check at the outside of the home to make sure that the vent exhaust hood is not blocked.
  • Check the flexible vent connection behind your dryer. Make sure that it is not kinked or clogged.
  • You can disconnect the flexible vent and start a cycle with the dryer venting directly into your laundry room. If the AF code does not appear, this will verify an exhaust vent duct problem. Otherwise you may have a component failure.
  • Have your home dryer venting run cleaned professionally.
hope i was able to fix your problem,
tnx 4 using fixya,
drcool
Posted on Oct 04, 2008
My kenmore elite mod. # 110.67062600 keeps flashing af
It is due to low air flow (AF),clean the vent tube out. The easiest thing to do is disconnect the vent and run the dryer, the AF will not be displayed, you can take the back top panel off an on the inside is a sheet with codes and how to take apart your dryer, as you have lint inside the dryer as well and should be cleaned out at least twice a year, varies on usage. Hope this helps Tim
Apr 07, 2011 | Kenmore 67032 Dryer
I have a whirlpool electric dryer (cabrio) every now and then it displays a code of AF what does that mean
I checked all the obvious things posted throughout the internet about this code on my 5 month old WED7800XL and none of them were the problem. What I found on my dryer was the belt that drives the fan had come off. After further inspection I also noticed that the pulley on the top of the fan was missing. After removing the front panel from the dryer I found the pulley, reinstalled it and the belt, the removed panels and it was fixed.
Also FYI, underneath the electronic panel there is a service manual for the dryer.
Dec 26, 2010 | Whirlpool Dryers
AF error will not go away after cleaning vent and lint filters
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
Nov 29, 2010 | Kenmore 67062 Dryer
The dryer display for the time is displaying "AF".
"AF" means there is an air flow problem within the venting system. There is either a restriction in the hose, outside vent cover, the front vent, or maybe the lower blower assist isn't rotating.
Nov 13, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Display is flashing AF what does that mean?
depends on dryer but problibly air flow prob, check house venting system
Apr 24, 2010 | Kenmore 67032 Dryer
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
AF On Dryer
I went to Lowe's where I bought the washer and dryer and asked them about it. They told me what to do
May 11, 2009 | Maytag Bravos MTW6600T Top Load Washer
''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Apr 23, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Kenmore Dryer displaying erroneous letters
AF is restricted airflow clean lint filter and check your vent hose for kinks or obstuctions
Dec 02, 2008 | Kenmore 67082 Electric Dryer
Kenmore 67082 Electric Dryer Logo
492 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
