Question about MA Audio HK15X2 Car Subwoofer
Searching for the right amp
What type of amp would you install with these subs, 4ch,bridge,2ch or mono,and what brand and how would you go about it if $ no problem?
A kenwood 1800watt d class mono block cost ruffly $600
Posted on Oct 04, 2008
Bridge 2 10's to a 2channel amp
most times it is L+ and R-. If the amp is bridegable. Also, make sure you don't go to low in the ohms. If your amp only runs at 4 ohms mono. Don't bridge it down o 2 ohms mono. If you have dual voice coil subs. bridge the coils of the subs in series, then bridge the two subs outside the box parallel.
Dec 25, 2014 | Car Audio & Video
Hifonics colossus-ltd dual monoblock amp does not have much output, running a cerwin vega stroker dual 2 ohm sub wired 4 ohm load bridged
Bridge at 4ohms your only getting 600watts rms. You will need to bridge at 1ohm (parallel) and adjust the gain accordingly. This will give it 1600 watts rms. If you would of had a dual 4ohm sub, then you could of bridged it at 2ohms mono, but you can't you have to go either 1 ohm or 4ohm. I believe it's not getting enough power.
May 20, 2012 | Hifonics Colossus-ltd Dual Monoblock 3200w...
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
How to bridge a 4ch power acoustik amp to 2ch
I had the Power acoustik saphire 4ch and had to do the same thing. Use the Positive from Term1 (spkr1) and Negative from Term2(spkr2). Good Luck.
Nov 26, 2009 | Power Acoustik GOTHIC OV4-800 Car Audio...
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Spl 6ch amp
When you want to bridge the amp... Take a look at the speaker terminal on the amp. I guess there is vritten how you connect ordinary and bridged.
Many amps have a button where you can choose how many channels you want. If you just have one pair off signal cable, you must choose 2 on the switch
Jul 20, 2008 | Car Audio & Video
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
How to brige 4ohm 12"sub primire by prioeer double coil
You can't run TWO subs on the bridge!!!!! You will destroy the amp! Put ONE sub on EACH channel.
Sep 14, 2007 | Kicker KX400.2 Car Audio Amplifier
MA Audio HK15X2 Car Subwoofer Logo
176 people viewed this question
Top MA Audio Car Audio & Video Experts
Robert Rankin
Ronald Prier
Level 1 Expert
sonic boom...
sonic boom...
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
