Question about Canon PIXMA MP460 All-In-One InkJet Printer
Error message U051 on canon MP460
I recently purchased 2 ink cartridges from ebay for my printer, they are refills, and obviously they have refilled old ink cartridges for the MP460 (Black-PG50/PG40 and Colour-CL51/CL41)
I thought this would be a good idea as it is recycling.
I have added my 2 new cartridges to my printer and installed them both properly, however my printer comes up with the error message-
"U051-The following ink cartridge cannot be recognized" and it has a picture of the 2 cartridges side by side with labels B&C.
I was warned before finalising my purchase that this may happen but was advised to "overide it".
I've been able to "override" refilled inks that are not recognisd by a printer on many occasions before on all types of printers, but cannot seem to do it on my MP460.
Is there a solution to this error message or have i wasted my money on something that i thought was good for the enviroment?
Any answers/solutions would be very gratefully recieved and appreciated.
Thank you very much
Jade King
  • 1 more comment
  • katiehawkins Oct 20, 2008
    My canon printer MP450 keeps coming up with the message UO51. The following ink cartridge cannot be recognized. We replaced the cartridge but still having problems. Any Suggestions? We have tried numerous things to try to fix.
  • Anonymous Feb 04, 2009
    My Cannon MP 460 printer has error 5100.
  • Anonymous Apr 29, 2009
    same problem
  • Canon Master
  • 5,309 Answers
Check the Label on the cartridge if it covers a certain area then you will get an error message. Compare it with a good cartridge the label should nearly touch the lugs at top end. Only applies to refilled Carts.
Posted on Feb 02, 2009
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
Check ink U051 code for a Canon printer
For starters, make sure the cartridge you have put in is the right cartridge for the machine. If it is, try pressing the STOP/REST button to cancel tthe message. Also try powering the machine down and re-seating the cartridge. The cartridge may have dirty contact, try cleaning them gently with a tissue and methylated spirits.
If the cartridge is brand new, you may have to either send it away to Canon for a replacement, or take it to where you bought it from for an exchange.
If the cartridge has been refilled, you may have to follow the reset procedure for refilled cartridges. On most Canon printers, simply holding the STOP/RESET button down for about 7 secs will turn off the ink monitoring level for the cartridge that the message is for.
Hope this helps.
Apr 13, 2010 | Canon PIXMA MX310 All-In-One Printer
I refill the ink cartridge colored and its says check ink u051 colored
it is not advisable to refill ink cartridge. it will only damaged you cartridge. but if you are trying to save money then refill ink cartridge ONCE only.
Feb 25, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MP460 will not recognize its own brand ink
Try removing the installation of your printer then install it back again. If you do not have the drivers, you can find them on Canon's site.
Hope that will help!
Feb 21, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Apr 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP180
There is no way to reset the ink levels on the new canon cartridges. you need to turn off the ink status monitor :(
You'll know it's time to refill again when your printing starts to fade, streak, or discolor.
Aug 24, 2008 | Canon MP610 Photo All-In-One Printer
Error message UO51
Are you using official Cannon cartridges or "ink refill" cartridges? Did you reset your ink levels in the software?
Jan 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP180 Ink Problem
lads ye're all I work in an 'ink place' and the u051 fault is a fault indicating that the offending cartridge is electrically dead, this is caused by the clever little program in the canon machine that writes info to the cartridge to make it'dead' so it cant be re-used ! possible solution is to get refilled before printer thinks it empty !!
Feb 09, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
3,102 people viewed this question
old marine
old marine
