Question about Archos 404 Digital Media Player
The scheduler will not work
I can real time record just fine using the docking station. I have sync'd the docking station with the cable box and the archos remote control will turn the cable box on and off. Customer service was worthless. Is there a "mystery" setting that I have missed. PLEASE HELP!! This is a fantastic player but I would like to use the scheduler function as that I paid alot for the DVR docking station.
SOURCE: Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Posted on Dec 13, 2007
SOURCE: connecting to a tv
YOU NEED TO GO TO SETTINGS ANDCHANGE THE PLAY MODE TO PAL FORMAT
Posted on Feb 12, 2008
SOURCE: DVR to Archos
That's what the DVR does. All you need to do is play whatever program you would like on your cablebox/DVR and hit record on your archos. It will record it like any program.
DamPinou
Posted on Mar 29, 2008
SOURCE: dvr docking station
I think the problem is that you have not got the unit set for your sky box. Put your archos into the dvr this should allow you to enter into the record button then press menu and settings and this will allow you to select different settings , i don't have sky but my first to settings are set to "auto", i have tried changing to something else and i lose the signal. Hopefully this is what you are experiancing. Good Luck
Posted on Jan 15, 2009
  • 8 Answers
SOURCE: Transfer file to Archos 5 using usb port on DVR Station Dock
On your Archos 5 go into tools -> Files and you should have two Archos 5 tabs. Change one to your USB stick and the other to the Archos 5 and copy and paste. I have not tested this, but this should work.  Good Luck.
www.blogger.usarchos.com
Posted on Feb 02, 2009
Not able to get an IP from the network when connecting thru the Targus docking station model ( APC51US) i am on windows 7. note that i am using the same cable adn it work fine when i connect it to the...
In order to use the ethernet card on your Docking Station ( or Port Replicator), you must first disable any internal Ethernet cards.
To do this:
  1. Type "Network Connections" in the Start Menu seach box, and press enter.
  2. Right click on your computer's internal ethernet adapter (i.e. "Local Area Connection" & select "Disable"
Ref: Targus Support
Apr 19, 2011 | Targus Port Replicator, Docking Station,...
Edifier brand docking station works with my ipod nano with auxillary cable but will not work in the docking port - no sound and no charging. Please suggest a solution. Many Thanks Stephen
There might be some issue with the docking ports. Try to connect a different iPod and see if its working, if its not working then there is some problem with the Dock connectors in the docking station.
Oct 10, 2010 | Audio Players & Recorders
Only noise from PC to monitor through docking station
I have the same problem and tried down loading the lates drivers without any change. It was working fine. I was in the middle of listening to music when it started.
Aug 22, 2009 | Toshiba Dynadock Port Replicator, Docking...
My Archos 605 WiFi will not always switch my NTL (Samsung) set top box on to make a scheduled recording.It will however change it to the correct channel if the box is left switched on and make the...
I have partly solved the problem by leaving the box switched on (any channel) then when the programme is about to record Archos 606 WiFi will switch the cable box to the correct channel and record. It will not however turn the box off after recording this has to be done manually using the remote handset.
In the instruction manual for the Archos docking station there is a footnote saying that in very rare cases the On/Off function does not always work and I am wondering if the Samsung (NTL) Box is one of them. I cannot get a direct answer from Archos support team on this issue when I have sent numerous E-mails. According to the manual I am working on the correct code number for the Samsung (NTL) box.
Feb 19, 2009 | Archos 605 WiFi Digital Media Player
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Dvr docking station
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
Dec 31, 2008 | Archos 604 WiFi Digital Media Player
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
Cannot Record using VHS
The question here would be one of two things. Obviously without probing further it would seem you're having an "unusual scheduled recording" issue. But, without further information it's difficult to tell.
For one, are you recording from straight signal (cable or antenna into the RF IN of the unit), or are you recording from a box (cable or satellite receiver or D/A converter, etc)?
Do your scheduled recordings record the first and not even pick-up the second, or do they record but only record static?
These are questions that will need to be answered before further assistance can be provided.
Feb 20, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Archos 605 wifi 4gb DVR issue
the power is low because you did the
same thing as me not chargeing it before you turn it on first
Jan 21, 2008 | Archos 605 WiFi Digital Media Player
Archos 404 Digital Media Player Logo
35 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
