Question about Dishwashers
Error code e1 lg dishwasher - Dishwashers
  • 3 more comments
  • my_fourleaf Nov 26, 2008
    What does it mean when it flashes E1?
  • naoual_ziani Dec 21, 2008
    I have an LG dishwasher which signal an E1 error and I don't know how to solve it.
  • larryd54 Jan 30, 2009
    Same problem. Dishwasher flashes E1 partway into either a wash or rinse cycle and stops.
  • Anonymous Mar 08, 2009
    dishwasher will start then halfway will stop with E1 Error how can I fix it
  • r_rat2 Apr 03, 2009
    e1 code with ding ding sound---1/2 way through cycle. Appears to have to much suds/water in base of unit. Waited 2 min with door open in attempt to disapate suds. Reset unit to normal, and re-ran cycle. The process of re-starting includes draining the collection base. Did not add any more detergent.
    There was noted an increadible howling sound from the machine prior to e1.
Can be one of the following:
Water leakage in Hose connections.
Water is leaked by damages.
The Motor Water Seal leakage of
Sump assembly.
The height of Drain Hose connection
(sink-Drain Hose) is not over 20.
Impeller of the Washing Pump is
worn away.
Posted on Mar 20, 2009
  • 3 Answers
SOURCE: lg dishwasher ld2120w is displaying
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. I resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first. I think the origin of the problem might be too much food on the plates and too strong of a dishwasher gel detergent so the food is turned into gunk which coats the channels of the plastic assemblies.
Add a comment
Posted on Nov 07, 2010
  • 110 Answers
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Posted on Dec 27, 2007
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
chargerhp
  • 813 Answers
SOURCE: LG Dishwasher LD-2050WH with HE error code
LG Told me the water coming in was to hot and to disconnect power for a few seconds and reset water heater to around 120 deg
Posted on Jan 31, 2010
  • 3 Answers
SOURCE: LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
How do I reset e1 error code on LG dishwasher after kid puts dish soap in the machine?
The suds may have caused water to run down into the pan under the unit. Take the front kick panel off and look for water under the unit and in the catch pan.
Jul 01, 2017 | LG Dishwashers
1E error code
Search Results
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Dishwasher Pump and Motor Assembly Replacement - LG ...
Sep 30, 2015 | Dishwashers
My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Sep 25, 2015 | LG Dishwashers
E1 error code on omega dishwasher
? 2:40
Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
Aug 28, 2015 | Dishwashers
What can I do for an E1 code?
Hi liyoung,
The full description on what to do is located in my Tip below:
L.G DISHWASHER E1 ERROR...
Hope it helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it.
Jul 19, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
My dishwasher LDF6810ST is showing an error code E1- I tried the checks that fixya gave me - there are no leaks. I called customer service and he said I would need a repair man. Please refund my money
Hi ardyhansen,
Please check my tip on a solution for this precise error, hope it helps:
CLICK HERE -> L.G DISHWASHER E1 ERROR
Kind Regards :-)
Jul 09, 2011 | LG LDF6810ST Stainless Steel Built-in...
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
Lg dishwasher lds 5811st E1 error code
Hi Chaz,
The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
Unfortunately the motor/impeller is only available as a complete assembly
Hope this helps
Col
Dec 11, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
1,505 people viewed this question
Top Dishwashers Experts
