Question about Canon FaxPhone B95 Plain Paper Inkjet
Documents in memory have disapeared
My fax machine ran out of ink. I had to go out and buy some, and when I came back, the documents were not in the memory... any chance I can get them back?
    Genius:
  • 2,120 Answers
Sorry, no.
Posted on Oct 04, 2008
I can't erase the faxes I already send
Hi There,
While not as popular as they were before the Internet became a principal means of business communication, fax machines are still an essential item in many offices. They are particularly useful on business documents when a signature is needed. Canon makes a number of fax machines that use both ink-jet and laser technology to receive and print documents. Most fax machines store incoming faxes in memory so you can reprint them, but occasionally the memory becomes full resulting in an error message. Your Canon fax machine's memory can be cleared quickly and easily so you can start using it again.
Instructions
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
Nov 27, 2011 | Canon Pixma MX410 All-In-One Printer
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
MY FAX MACHINE CAN NOT RECEIVE FAX FROM OTHER, THE DISPLAY IS FAX MEMORY FULL, HOW TO SOLVE?
This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Mar 15, 2011 | Computers & Internet
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Fax memory says full. how do you get them(Panasonic KX-FG2451)I haven't been able to receive faxes, don't know if this would effect it.
    The memory is full of received documents due to a
    lack of recording paper, a lack of ink film or a
    recording paper jam. Install paper (page 13), install
    ink film (page 11) or remove the jammed paper
    (page 63).
    the entire manual here http://service.us.panasonic.com/OPERMANPDF/KXFG2451.PDF#page=53
    Apr 17, 2009 | Panasonic KX-FG2451 Fax
    Read fax in memory MP830
    it won't print faxes if ink is too low so it stores them until you replace the low cartridge or cartridges. Don't know if you can transfer to computer. Do it the other way around and go to www.myfax.com I did and I love it.
    Feb 24, 2009 | Canon MP830 All-In-One Printer
    Toner ran out on Muratec f300
    SORRY CAN'T BE DONE. FAX FORWARDING RULES HAVE TO BE IN PLACE "BEFORE" DOCUMENTS ARE RECIEVED INTO MEMORY...THE F-300 ONLY HAD FAX FORWARDING IF IT WAS P.C. CONNECTED AND USING "OFFICE-BRIDGE"
    Nov 12, 2008 | Muratec F-300 Fax
    Auto print off
    Most often, Auto Print Off is activated by pressing the On/Off button, and documents are then stored in memory. Disable this function by pressing the On/Off button again.
    The fax will also turn off Auto Print when the machine runs out of ink or paper, in which case, you should replace the ink cartridge or supply more paper. This situation usually results in display of the message Rec'd in Memory as well, and the unit will receive up to 30 transmissions or 60 pages maximum.
    Please post back if you need further help, otherwise thank you for using and rating FixYa!
    Jun 07, 2008 | Canon FAX-JX200
    Canon jx200 fax machine
    The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
    Faxes can be retrieved as follows.
    If you want to choose only certain faxes to print:
    1. Print a list of documents in memory for reference:
    Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
    2. Print a document from memory (using the list printed in #1):
    Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
    Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
    3. Delete selected document(s) from memory:
    Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
    Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
    If you want to print all unprinted documents in memory:
    1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
    2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
    3. Delete all printed docs from memory:
    Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
    To delete all documents at a later time:
    Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
    If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
    Jun 06, 2008 | Canon FAX-JX200
    Printing
    REPLENISH PAPER OR INK ,THE MACHINE WILL NORMALL;Y PRINT ALL RECEIVED MEASSAGES HAPPY FAXING OMNIPRESENT
    Apr 13, 2007 | Samsung SF-4500 Plain Paper Thermal Fax
    Canon FaxPhone B95 Plain Paper Inkjet Logo
    63 people viewed this question
    old marine
    old marine
