System recovery stops on disc 3. message reads: the file C\PRELOAD\BASE_16.INP cannot be recovered.
  • Anonymous Jan 04, 2009
    I've been experiencing the same problem with my HP DV5237, but at the fourth disc!
  • 298 Answers
SOURCE: e-recovery stalls at about 40%
If you have Fat 32 one of the methods
on the link below may work
http://forum.notebookreview.com/showthread.php?t=50790
Posted on Dec 09, 2007
Chadha Saab
  • 142 Answers
SOURCE: recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Posted on Feb 19, 2008
SOURCE: word file corrupted. Recovery
Hi this is Tshepo More - South Africa.
1. Perhaps it's a Read-Only and requires some credentials before opening it or ACK to the sender that you have opened his/her doc
2. Did you try virus scan?
3. Try latest Recovery Suite
Regards
Posted on Mar 10, 2008
  • 233 Answers
SOURCE: System Restore (Destructive) GM5084 Gateway Media Center w/ XP
So you have an OEM Windows disc with the activation code? You should be able to install the OS from this. Try taking the battery out for an hour then installing XP. Also go into setup and set the CDROM as first boot device. If Windows installs go back and change first boot device to HDD. If it still won't install try a different CDROM drive. I have heard that some CDROM drives will not install XP. I don't know why but I've heard this rumor. There is also a jumper on the motherboard that resets the CMOS to default. I think it is J1, J2? Try switching that to the other position and turn on the unit. Shut down and move the jumper back. That is all I can think of right now.
Posted on Jan 01, 2009
billspeer
  • 180 Answers
SOURCE: HP System Recovery Stuck at Disk 5
I had this same problem when I was restoring as well. Are these the Recovery Discs you created or did they come with the system? I had to call up HP and tell them the situation. Since you only get one shot at creation of the discs, there is no way to recreate them. They were kind enough to send me their set of discs at no charge. I'm assuming it was because I had done my job of creating the discs as directed, but the system botched the job. Good luck. I'm sure they'll do the same for you.
Posted on Feb 15, 2009
How do I recover deleted messages on an Iphone 6?
First, download the iTunes and backup all the data of your phone.
Then, go to the official website and download the data recovery software. It is likely call Frombyte Recovery For IPHONE.
Next, scan file you need by the data recovery software.
After scanning, you can recover your deleted messages.
Oct 09, 2015 | Apple iPhone 6
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
Message missing operating system
This sounds like the main partition on your harddrive was corrupt. You will need to reformat the system.
Using the Recovery Partition:
1. Press [F9] during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click
Next.
4. Read the ASUS Preload Wizard messages and click
Next.
5. Select a partition option and click
Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other
partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Feb 28, 2013 | ASUS X53U-RH11 New
Deleted sms recovery
Whether you can recover texts from a broken Android phone or not,you can recover SMS messages on Android phone. However, it depends on the broken phone itself. If it can still be turned on, there is a chance. Moreover, you'd better not created new data on your phone after the message loss, such as sending or receiving messages, etc. Now, let's be optimistic. The phone mentioned above still can be switched on.
There are many Android tools out there that can recover deleted text messages from Motorola, like: Vibosoft Android Mobile Manager, Coolmster Android assistant
Vibosoft Android Mobile manager:
http://www.vibosoft.com/mobile-phone/how-to-recover-deleted-text-messages-from-motorola.html
http://www.coolmuster.com/android/motorola-sms-recovery.html
Nov 23, 2012 | Motorola Mobility Defy Cell Phone
C:\preload\data9_04.inp cannot be recovered
You can recover the file with 3rd party data recovery software.I have succeed to recover files from external hard drive with Tenroshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost files. By the way,you can download it and scan your hard drive for free to preview whether your file can be recovered. Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Jul 31, 2011 | HP Media Center m1080n (PC099A#ABA) PC...
I erased all my photos now my camera read memory card error. i tried replacing the card but the camera still reads the same message.
I have had success with this... Download this camera photo recovery program called asoftech photo recovery
http://www.asoftech.com/apr/index.html
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Jul 06, 2011 | Canon PowerShot SD800 IS / IXUS 850 IS...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
Feb 15, 2009 | Computers & Internet
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
