Question about Garden
Strimmer Line I can't get the strimmer line to bump feed from my RYOBI Srimmer. This is the first replacement and i'm obviously doing something wrong when wrapping it onto the spool....any help greatly appreciated...
  • 659 Answers
Rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Restring a pgt300 performance power strimmer, it has a white casing which does not come off preventing me from adding more line
There should be 2 plastic tabs which you have to push in, this removes the wider outer base cover of the strimmer spool, giving you access to the bump cap and line spool.
Depending on the style you have, one looks to be a whole replaceable spool unit, one looks like a re-threadable spool.
If you find this useful, please click the 'helpful' tab. Thank you
May 14, 2016 | Garden
Hoe does the automatic line feed work on a line trimer
Richard the auto line feed works by bumping the head when the strimmer is running. If it's wound right the line comes out when you tap the head on the ground when on full running.
Jan 12, 2014 | Garden
Spear & Jackson 33cc Petrol Grass Strimmer SGT33N, black fuel pipe split. How to replace it?
empty the petrol,feed the black line (the fuel intake) into the tank and grab the end of it thats attached to the filter inside the tank. now you can feed a new fuel line through into the tank and reattach to the filter. hopefully this will solve your problem ive just done this but mine still wont start, either flooded or spark plug. by the way i bought mine new and the fuel line was split.
Jun 05, 2013 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Ryobi RPT 254c strimmer, how do I wind the line so I stop losing the line
You are winding the line on the spool in the wrong direction. The line should be wound on in the opposite direction of the way that the head spins during operation.
Jim
Aug 16, 2011 | Garden
Hi I recently bought a Ryobi RLT26CDS. Every time the thread needs extending I have to undo all the gadget and manually pull and extend the thread. could you please tell me how I could extend the thread...
'Bump' the strimmer line unit on the ground (this is how it releases the line)-It sometimes gets stuck(welded to the sides if the release chamber-it gets hot and melts)-
hope this helps
Jun 07, 2010 | Ryobi Garden
Ryobi strimmer
i can not take the cover off to put the line back in
Jun 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Ryobi model RCT2800B grass strimmer will not start
close your carb adjustment screw a bunch of turns... yours may even be missing.
Apr 19, 2009 | Ryobi Garden
Garden Logo
436 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
