Question about Cameras
K100D AF/MF SWITCH STUCK IN AF - Cameras
    President:
  • 1,952 Answers
I
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Posted on Oct 04, 2008
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Oct 04, 2008
    First make sure the MF/AF switch is set to AF(this raises the
    > autofocus screw and pushes the pin up). Then get an automotive feeler
    > gauge or some other small thin piece of metal(credit cards are too
    > thick, paper is not strong enough), and stick it between the body and
    > lens near where I have the little red arrow(you can also look back up
    > at the other picture of mine so you know where the AF screw is at).
    > You will feel the AF screw when you run into it. When that happens
    > try gently twisting the lens off, if it doesnt work keep moving the
    > feeler around in there, and trying to twist the lense off... always
    > be gentle, dont poke or twist too hard, you will get it eventually.
    > After you get the lens off you can follow my instructions above for
    > removing the pin.
    Image control: Zoom out | Zoom 100% | Zoom in | Expand / Contract | New window
    Here is the thread in dpreview that I learn about the issue and from
    what I understands, if the AF quick shift is pushed to engage the AF
    lock, the push of pin from your K mount may yield a kick/push on the
    stuck lens and give you a bit of wiggling room to have a better chance
    to free up your lens. Whatever you do, try to do it as patiently as you
    can, there is no need to wiggle hard.
    mohammed marika thambi Oct 10, 2008
    have u got cleared?
  • 13,433 Answers
Heres your user manual
http://www.manualnguide.com/dl/2226/
    Genius:
  • 1,550 Answers
Can you be more clear with your problem . When you are facing this problem ?
Have you done basic troubleshooting techniques like replacing new batteries, gentle tapping on camera
  • SAM ANDERSON Oct 04, 2008
    Post back the required details .
CAN NOT FOCUS THE CAMERA WITH OR WITHOUT MEMORY CARD
The memory card has nothing to do with the focus system. Not knowing what camera you have, I have to guess.
Check the camera is on Automatic. When it is a DSLR or system camera, check the AF / MF switches, both on the camera and on the lens.
Eventually check in the menu if you can switch from AF to MF and in any case, switch to AF.
Check if you can focus manual, or perhaps he camera can't focus at all. Then check if you did connect the lens correct.
Jan 23, 2015 | Cameras
My camera will take a photo in MF but not AF
And you are sure the AF MF switch on the lens is set to AF?
If so, check the contacts on the lens and in the camera. They should be clean and shiny and have on dent. Only clean with a dry cloth and cotton swab. Never use anything sharp in or close to a camera or lens.
Oct 10, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Help! My canon 85mm f/1.8 af/mf switch isn't working
That is going to have to be sent back to Canon for repair.
Jan 09, 2014 | Canon EF 85mm f/1.8 USM Telephoto Lens
THE AF AND MF ON THE LENS MEANS WHAT
AF=Auto Focus. With an autofusu capable body, the camera will automatically focus for you using preset focusing zone. Move the Switch to:
MF and it becomes a manual focus lens, where the photographer has to manually focus on his subject.
Nov 18, 2010 | Cameras
Auto focus on my d300 does not work
There is a [MF - AF] switch on the camera body where the lens attaches to it.
Move the switch to the AF selection.
AF = AutoFocus
MF=ManualFocus
Sep 24, 2009 | Nikon D300 Digital Camera
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Lens
If this is a manual focus lens, you will need to do two things (and an optional third thing.)
1) On the side of the camera, you have to switch the focus mode switch from "AF" (Autofocus) to "MF" (Manual focus) . . . Yeah. I know, you probably already did that. <grin>
2) When you press Menu, go to the Custom Setting and change the Allow aperture setting to on, so that the Pentax K100D will then work with manual control of the aperture ring. You need to do this or the K100D will not work with manual exposure lenses (M lenses) or even autoexposure lenses (KA, KA2, FA, etc.) when you move the aperture ring from the "A" position to one of the manual aperture settings!
3) This is optional, but in the Custom Setting you can also turn on the Fl in manual focus mode, so that even though you don't have autofocus capability, you will get a beep indicator when you have successfully managed to manually focus your lens.
I have a few nice manual focus lenses that I have a lot of fun playing with on my K100D.
Take care & Happing Imaging!
Glen
Jun 09, 2008 | Pentax K100D Digital Camera
Pentax K100d super
I fixed the problem. It was caused by an extra little pimple on the sirius lens slipping into the auto focus indent indent on the camera body.
It is possible to get up to a ten thou engineers feeler gauge into the gap between lens and camera body although the one that did it for me was a three thou gauge.
I needed to cut the feeler gauge square at the tip and then, even though it was only three thou, I hit the tip by resting on a vice and tapping with the ball end of a small ball pein hammer. This caused the tip to form with a small curve. I then used a tool makers file to smooth the end down to almost nothing.
Turn the camera AF MF switch to AF to raise the screw. Fiddle the feeler gauge into the slot between body and lens just near the AF MF button and very gently probe the gauge. You are trying to get the little curve you made on the feeler gauge to slip over the pimple on the lens.
Its a very nice feeling when the gauge slips right in and the lens comes free.
The next proceedure, if you want to use the lens, is to unscrew the aluminium mount at the end and remove the offending pimple on the lens.
May 31, 2008 | Cameras
Cameras Logo
185 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
