Washing machine wont take the conditioner.Have thoroughly cleaned soap dispenser drawer
This video will show you how to keep your soap draw clear
and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
SOURCE: bosch max wfl2000 washing machine
I am a recently retired appliance engineer of 20 years sounds like a faulty cold supply, or just no water getting to machine, if water supply ok check the water solenoid, check for open circuit just try that to start with, hope this helps if so rate me please
SOURCE: Conditioner is not used in the wash cycle
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
SOURCE: Ariston A1635 Washing Machine
Soap drawer clips in. Make sure you open fully then pull straight out. to replace make sure you slibe in to runner on door and push in until it locks. Problem may be in the syphon tube. may be clogged or in the unit we had the tube was not open at the bottom.
SOURCE: Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
SOURCE: Conditioner drawer not emptying
Do you use a thicker type of softener? When I had this problem with my washer I added water to the softener to thin it out, as it just seems like it leaves a build up that clogs repeatedly otherwise. hope that helps
