Question about Mtd 22" Yard Machine Push Mower
Mower will not start. starter is stuck.
I can not pull the string to start the mower. it seems to be stuck.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Is this solved?
Posted on Jan 10, 2009
Take the plug out and try again. I thatdoesnt work, take the air cover off, approx. 4 or 5 cap screws and see if something is binding. If this doesnt work try to turn the mag wheelk if that doent work, you probably have avery loose rod cap or broken rod.
Posted on Oct 15, 2008
The starting cord is jammed and will not pull.
you may need to remove the 3 or 4 bolts that hold the recoil on the starter string to the mower. this is not a big deal just be careful as the starter rope may recoil when removing.
Apr 10, 2016 | Garden
How can I fix a tangled up cord in my lawn mower I let it go to far in side and now I can't pull the cord out to start
You will have to remove the starter recoil assy. It's pretty easy actually.
Go on you tube and type in how to install new string in starter pull assy...or rope assy etc...
Oct 21, 2015 | Garden
I cant pull the string to start the mower
pull plug out tie up bail handle see if you can turn engine over by hand if you can pull hard on rope it has jamed if not .move check for locked up mover add oil to cylinder for it to turn over till its free my have to take recoil off to do this if the reciol starter pawls or lock in
Aug 30, 2014 | Garden
Pull cord on my lawnmower is inoperative
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Dec 07, 2012 | Craftsman 55 Torque 158cc 22" Push Lawn...
I have a 1970 simplicity riding lawn mower (6 hp) pull string stuck. How do I repair it?
You are going to have to remove the recoil starter to see why it is hanging up. May have to deassemble to repair, or replace.
Jul 14, 2011 | Garden
Bought mower used has nt been started in a while .when try the manual pull start the string does nt retract
sounds like the impeller on the underside of the starter mech is broken
Mar 06, 2011 | Garden
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
My mower worked fine last week. went to start it and had no spark and feels like the self propel is still engaged. The pull string is hard to pull and the mower wants to go when pulling the...
hard to mow a lawn pulling the starter cord all the time,lol,,,ok, no spark...you have an engine control bar at top of handle, cable runs from it to engine brake, and this is also engine kill switch. sounds like this cable has stretched. this cable controls engine brake and also kills the spark. you have two problems, and this controls both.
Apr 29, 2010 | Garden
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Pull start won't pull, seems stuck.
When you pull the cord it will turn the blade. Therfore if the blade is stuck or clogged with clippings the starter cord will seem stuck. In addition, the throttle on the handgrip need to be fully depressed for the starter cord to work. Last, some mowers have a saftey which lock the starter if the wheels are engaged. Hope this helps. Bob
Apr 11, 2010 | Garden
Mtd 22" Yard Machine Push Mower Logo
345 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
