Question about Dishwashers
BOSCH DIDHWASHER MODEL SG159AO5AU/4 4-1/2YRS OLD.POWER BLACKOUT THROUGH MIDDLE OF CYCLE NOW WATER DOES NOT PUMP OUT.
I solved the problem. It was only a co-incidence that the washer did not pump the water out after the power came back on.
First of all i had to see if the whole program worked and yes it did. I then had to verify to myself wether it was a program fault or a mechanical fault or a combination of both.
I began to dismantle machine to do a physical examination of pump. Upon my disbelief i had found a 1/2 pistacchio nut shell next to the impellor and 5 popcorn seeds.Seeing the pistacchio shell gave me a great sigh of relief as you would imagine.My next job was to apply 240v to the pump to verify
that it was mechanically and electrically sound which it was.
Everything was put back together and a wash program run.Ran like a dream.
There's an old saying, "never assume".My wife assumed a power blackout stuffed it up.Turning the power off at the machine or a powerblackout is the same thing, the program will restart again once power is restored.
My great concern about this incident is how those objects got past 3 sets of filters , the course one on top, the finer one under that and the really large fine one at the bottom. Regards F.Flex.
Posted on Oct 07, 2008
Bosch dishwasher Water pump not stopping
Hi.
You need to replace the pressure switch located near to the pump, in the drain assembly.
The main function of the pressure switch is to turn off pump when there is no more water.
The pressure switch can be tested reading ohms on switch contacts and jumping the switch. This must be done by a technician.
You can get parts and a quote on repair calling Bosch at the number listed on the manual.
Regards.
Nov 20, 2009 | Bosch Dishwashers
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Water doesn't pump out
I had a similar problem with mine although it is a different model #. I fixed mine by removing a small plastic basket looking thing in the middle of the stainless steel screen looking drain. Just turn it counter-clockwise and lift it out. Mine was almost completely plugged with lime build-up. There are 2 parts to this and they snap apart pretty self explanatory if you examine it. Then just scrub off lime build up with old toothbrush etc. Bail out as much of dirty water as you can and re-asemble.
Dec 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Bosch built in dishwasher model # SHX46A02UC
sounds as tho you have a foreign object stuck in the drain pump. only solution is to remove drain pump and check
Jun 24, 2008 | Bosch Dishwashers
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shu3036 upper arm with low pressure
check water level should just appear above filter failing that a common fault on these is the impellor wings have worn you need to strip wash motor down to get impellor cover off
Jan 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
