Question about Optoma HD72 Multimedia Projector
Flashing standby,power on,lamp lights with no fan
Hello I'm having problem with my Optoma HD72 projector to where when I plg unit up and switch on all I get is flashing lights onthe standby,on and lamp icons on top of projector. What could be the problem? Item was brought in like new conditon for ebay auction though auction only mention projector there is no picture to projector. How can I fix this problem at this time? Can someone link me to a solution or help me? Thanks
  • LegendaryJ Oct 05, 2008
    Ok I got picture to show by wipping down insides. My only problem now is like most members here I get picture for a minute then a black picture with fans running. I hear it may be a bulb problem and a bulb driver problem. I want to be sure before I replace lightbulb. Brought projector from ebay for repair and hoped to got lucky because there problem was having no picture only. Bulb was in projector but I can not tell what is the time on bulb until menu can stay on. I am also wondering can I use the service port to do any fixes???
  • 431 Answers
Most problems with the lamps are covered in the manuels for these projectors , however none user technical difficulties are not .. ie where it is needed to open the unit not recomended to the untrained as a screwdiver in the wrong place can cause irepairable harm let alone death ?
To check if it is your bulb simply take the unit to an engineer for an estimate usually free at least you will know whats wrong and can go from there .. and if you do have a working bulb an ebay replacement is probably the cheaper conclusion to your problem ... regards Vortash
Posted on May 10, 2009
What does it mean when all three lights, standby, temp and lamp, remain solid on Optoma HD72?
I suggest you go to eserviceinfo and search for the manual on this unit, sometimes this indicates a filter door open or bulb carrier door not closed. But to be honest without seeing the manual ?, however you didn't say if the unit was working despite the lights or not. Check the doors to all compartments and see if they are closed properly, other than this advice I suggest you seek an engineer to check it out
Aug 18, 2014 | Optoma HD72 Multimedia Projector
Optoma hd72
It sounds like you bulb is ready to die. First clue is picture quality. That happen to me and a new bulb remedy the problem. Bulbs are expensive though.
Jan 28, 2014 | Optoma HD72 Multimedia Projector
Hello, I am having a problem with my hd72/hd6800. My projector is on its original bulb and has about 500 hours over 5 years. Today i was able to turn it on, but the lamp wont light up. I hear the fan start...
Despite the relatively few hours on the lamp, the fact is it's over 5 years old. It is not uncommon for a lamp to age and be too weak to fire. Replace the lamp, you should be fine.
Jan 25, 2011 | Optoma HD72 Multimedia Projector
Lamp flashing, hd72 projector
In most projector menus there will be an option to reset the lamp timer, it's usually under the "settings" area of the menu. Try resetting the lamp timer and the light should stop flashing.
Jan 17, 2010 | Optoma HD70 DLP Projector
Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
May 10, 2009 | Optoma HD72 Multimedia Projector
Optoma HD72 flashes red and green. I changed the lamp but the problem wasn't resolved. Any input would be greatly appreciated.! Greg
I had the same problem with flashing colors after playing for awhile. The following helped:
1. turn off bright mode from menu.
2. keeping the back side of the projector flat. I had it raised up about 3" on the backside before, not sure why but it worked fine when flat.
Hope these help you also.
Apr 11, 2009 | Optoma HD72 Multimedia Projector
Optoma projector switches off after 5 mins
AS regretable as this sounds component failiure was my first thought .. It's not the bulb temp sensor as the fan is opperating and that usually cuts all power .
You may find that as you have a bulb ( usually worth more than the units they reside in ) rather than a repair another unit of Ebay would be a safer and more economic conclusion ... Regards Vortash
Jan 14, 2009 | Optoma HD72 Multimedia Projector
HD72 - LAMP GOES OUT IN 30 SECONDS
The projector is sensing the amp draw from the bulb and shutting down due to out of spec draw...replace the bulb.
Oct 21, 2008 | Optoma HD72 Multimedia Projector
Short picture time when starting Optoma HD72 projector
Mine did the same thing. The bulb is used up...replace the bulb. That fixed mine, working great again.
Oct 05, 2008 | Optoma HD72 Multimedia Projector
Optoma HD72 Multimedia Projector Logo
515 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
