Question about ASUS K8V-MX Motherboard
Unrecognized HDD-- need help!
I have bought a 500 GB SATA HDD and the drive is notrecognised in bios at all.This seems to be the same problem that you have already faced. The motherboard that I have is "K8V-MX".Whatcould be the possible problem and how can I fix it?
Any help would be greatly appreciated.
Regards,
Pras
  • Anonymous Dec 16, 2008
    Hi, I have the same problem, my Hdd 500 GB WD is not reconognize by bios. So, I thought, it's time to upgrade the bios,and I did this. I have this problem still, even with new bios. Additionaly, I must sey than I have "K8VX". Meyby the last v of bios from end of 2005 is not submitet to operate with 0,5 TB Hdd. Anyones knows that?
    R76PL
  • Anonymous Dec 21, 2008
    not recognise my other hard drive
Same problem with the ASUS K8V-MX motherboard with a "Seagate Barracuda 7200.12 SATA 3Gb/s 3.5" 500GB Hard Drive ST3500418AS" not being recognised. Had to force the disk to use 1.5 GB/s mode, but connecting the jumpers as shown here: http://www.seagate.com/images/support/en/us/cuda_sata_block.gif
Once I did that the system would recognise the disk on the BIOS screen, and the operating system (Linux in my case) could see the disk.
Posted on Apr 19, 2009
R76PL
Posted on Dec 16, 2008
  • raga76 Dec 18, 2008
    Hi, Ok now its works, Is just that you saind Ev1LrYu, there was only problem with find information which pin should be conect. Ther was conflict beatwen HDD SATA II and Motherboardt SATA II. In WD5000AAKS for "limit to 1.5gb/s" jumper should conekt pins 5-6.
    R76Poland-PL
You could also try setting the jumper on the hard drive to "limit to 1.5gb/s".
Posted on Oct 15, 2008
I did have the same problem. But it was because I was using a hard drive that was set up for another motherboard and BIOS. When I booted up again from my XP disc and installed a new version of Windows XP, everything was fine. I did have a slight problem finding the correct BIOS setting for my 2x S-ATA DVD drives and my old 2x P-ATA hard drives. But by resetting the my combination of drives in BIOS "Storage Configuration" to "ATA/IDE Configuration ----Enhanced"; and the"" Enhanced Mode Support On -------[S-ATA], I managed to get my computer to work OK..
I don't really understand why, but who cares, it works.
Posted on Apr 15, 2009
  • 778 Answers
Do you have an IEDE hard drive installed if so remove it and try your SATA drive
I have a SATA drive and it will not recognise my IEDE drive
Posted on Oct 14, 2008
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
Hello
As i search about what you need to know about the 500GB SATA HDD can support in MOBO, i say YES!
865GBF Desktop Board
Two Serial ATA connectors
If there any question just add comments.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 18, 2009 | Intel D865GBF Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Hi, thanks, need more help
hi
i have problum with windows mother board not be installed a window xp in k8vmx
Oct 04, 2008 | ASUS K8V-MX Motherboard
HI thanks, need more help
what type of SATA HDD ,The make ?
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
ASUS K8V-MX Motherboard Logo
1,195 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Tony
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
